Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
11-26-2023, 10:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Age: 44
Member: 2911 Status: Offline Thanks Meter: 3 | Xperia pro-i. Boot loop / reboots Just got reboots, Sony logo only. I've tried to reflash usung Newflasher - same result. Also recovery reflash using Xperia Companion doesn't help - same result after reflashing. Tried to unlock bootloader using fastboot oem unlock 0xCODE - it is giving error : FAILED (remote: 'Command not allowed') Log file below( dump.bin ( newflasher Read-TA:2:2050) any ideas how to recover? Code: S - Format: Log Type - Time(microsec) - Message - Optional Info S - Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic S - QC_IMAGE_VERSION_STRING=BOOT.MXF.1.0-00589-LAHAINA-2 S - IMAGE_VARIANT_STRING=SocLahainaLAA S - OEM_IMAGE_VERSION_STRING=ip-10-26-16-222 S - Boot Interface: UFS S - Secure Boot: On S - Boot Config @ 0x00786070 = 0x00000001 S - JTAG ID @ 0x00786130 = 0x301350e1 S - OEM ID @ 0x00786138 = 0x00780001 S - Serial Number @ 0x00786134 = 0x3dd46605 S - Feature Config Row 0 @ 0x00784148 = 0x0000000000000000 S - Feature Config Row 1 @ 0x00784150 = 0x0000000000000000 S - Core 0 Frequency, 1459 MHz S - PBL Patch Ver: 3 D - 9307 - pbl_apps_init_timestamp D - 49675 - bootable_media_detect_timestamp D - 8279 - bl_elf_metadata_loading_timestamp D - 25099 - bl_hash_seg_auth_timestamp D - 18875 - bl_elf_loadable_segment_loading_timestamp D - 4547 - bl_elf_segs_hash_verify_timestamp D - 16961 - bl_sec_hash_seg_auth_timestamp D - 814 - bl_sec_segs_hash_verify_timestamp D - 26 - pbl_populate_shared_data_and_exit_timestamp S - 133583 - PBL, End B - 142526 - SBL1, Start B - 272883 - SBL1 BUILD @ 10:29:24 on Sep 16 2021 B - 276940 - usb: usb2_rcal , 0xa B - 280325 - usb: platform B - 283711 - usb: usb_shared_hs_phy_init: hs phy cfg size , 0xc B - 292281 - usb: eud_serial_upd , 0x3dd46605 D - 292586 - sbl1_hw_init B - 620614 - UFS INQUIRY ID: MICRON MT512GAXAT8U31 0102 B - 622779 - UFS Boot LUN: 1 D - 345717 - boot_media_init D - 0 - smss_load_cancel B - 645776 - SMSS - Image Load, Start D - 3050 - SMSS - Image Loaded, Delta - (0 Bytes) D - 25376 - Auth Metadata D - 26444 - sbl1_xblconfig_init B - 681278 - XBL Config - Image Load, Start D - 0 - shrm_load_cancel B - 688995 - SHRM - Image Load, Start D - 25041 - Auth Metadata D - 1281 - Segments hash check D - 33641 - SHRM - Image Loaded, Delta - (39808 Bytes) D - 0 - boot_default_cdt_init D - 244 - boot_cdt_init B - 734867 - CDT - Image Load, Start B - 737673 - CDT Version:3,Platform ID:8,Major ID:2,Minor ID:0,Subtype:0 D - 16592 - sbl1_hw_platform_pre_ddr D - 0 - devcfg init B - 763781 - PMIC A:2.0 B:2.2 C:2.2 D:2.0 E:2.3 B - 765611 - PM: Reset by PSHOLD B - 768447 - PM: Reset Type: Shutdown B - 771772 - PM: PON by SYSOK B - 1023488 - PM: SET_VAL:Skip B - 1023793 - PM: PSI: b0x00_v0x81 B - 1029192 - PM: Device Init # SPMI Transn: 15134 D - 275720 - pm_device_init, Delta B - 1034773 - pm_driver_init, Start B - 1046851 - no SDI. gcc_reset_status=2 B - 1048986 - S3_timer is set to 16sec B - 1050877 - PM: Driver Init # SPMI Transn: 598 D - 16409 - pm_driver_init, Delta B - 1060576 - PM: Battery ID: 15168Ohm B - 1062864 - PM: VBAT: 4347mV IBAT: 422mA B - 1566266 - PM: VBAT: 4405mV IBAT: -59mA B - 1566480 - PM: Charger port type: SDP B - 2070035 - PM: Primary Charging loop exit B - 2070492 - PM: CHG Init # SPMI Transn: 15833 B - 2074335 - vsense_init, Start D - 30 - vsense_init, Delta D - 1366858 - sbl1_hw_pre_ddr_init D - 0 - boot_dload_handle_forced_dload_timeout D - 3416 - sbl1_load_ddr_training_data B - 2129510 - Pre_DDR_clock_init, Start D - 91 - Pre_DDR_clock_init, Delta D - 12901 - sbl1_ddr_set_params B - 2141222 - sbl1_ddr_init, Start B - 2144638 - LP5 DDR detected B - 2163670 - eCDT MRR - Data Starting Address: 0x09066D00 D - 56120 - sbl1_ddr_init, Delta B - 2200697 - DSF version = 247.8.15 B - 2204082 - Manufacturer ID = 1, Device Type = 8 B - 2207651 - Rank 0 size = 6144 MB, Rank 1 size = 6144 MB B - 2212500 - DDR_INFO:LogVer=0002,type=0008,MR4=0x0000,0x0000,0x0000,0x0000,MR5=0x01,MR6=0x08,MR7=0x00,MR8=0x14 B - 2223724 - DDR_RANK:LogVer=0002 B - 2228360 - ** sdram0_cs0=1536MB,sdram0_cs1=1536MB B - 2231776 - ** sdram1_cs0=1536MB,sdram1_cs1=1536MB B - 2236931 - ** sdram2_cs0=1536MB,sdram2_cs1=1536MB B - 2242116 - ** sdram3_cs0=1536MB,sdram3_cs1=1536MB D - 106323 - sbl1_ddr_init D - 31 - boot_pre_ddi_entry B - 2255231 - do_ddr_training, Start B - 2297870 - DDR: Start of DDR Training Restore B - 2305129 - Current DDR Freq = 1709 MHz B - 2305159 - Max enabled DDR Freq = 3196 MHz B - 2309185 - DDR: End of DDR Training Restore D - 55144 - do_ddr_training, Delta D - 63013 - sbl1_do_ddr_training D - 671 - boot_ddi_entry B - 2324984 - Pimem init cmd, entry D - 9150 - Pimem init cmd, exit B - 2337581 - External heap init, Start B - 2340417 - External heap init, End UEFI Start [ 3106] - 0x09FC01000 [ 3109] Sec.efi ASLR : ON DEP : ON (RTB) Timer Delta : +2 mS RAM Entry 0 : Base 0x0080000000 Size 0x0037500000 RAM Entry 1 : Base 0x0200000000 Size 0x0180000000 RAM Entry 2 : Base 0x00C0000000 Size 0x0140000000 RAM Entry 3 : Base 0x00B9900000 Size 0x0000000000 Total Available RAM : 12149 MB (0x02F7500000) Total Installed RAM : 12288 MB (0x0300000000) Multithread : ON (Lib ver 1.2) CPU Cores : 8 (init 2) Init 1 aux cores of 7 Init CPU core 1 > Scheduler up on Core 1 CONF File : uefiplatLA.cfg UEFI Ver : 6.0.210916.BOOT.MXF.1.0-00589-LAHAINA-2 Build Info : 64b Sep 16 2021 10:29:57 Boot Device : UFS PROD Mode : FALSE Retail : TRUE - 0x09ECC8000 [ 3167] DxeCore.efi Loading DxeCore at 0x009ECC8000 EntryPoint=0x009ECC9000 HOBLIST address in DXE = 0x9EAB9018 FV Hob 0x9FC00000 - 0x9FEFFFFF FV Hob 0x9ED07000 - 0x9F0AFFFF FV2 Hob 0x9ED07000 - 0x9F0AFFFF 631008B0-B2D1-410A-8B49-2C5C4D8ECC7E - 00000000-0000-0000-0000-000000000000 - 0x09EC45000 [ 3171] XHwresetDxe.efi - 0x09EC3E000 [ 3171] MazeDetDxe.efi - 0x09EC65000 [ 3171] EnvDxe.efi - 0x09EC5B000 [ 3172] RscRtDxe.efi - 0x09EC53000 [ 3172] SCHandlerRtDxe.efi - 0x09E78D000 [ 3172] RuntimeDxe.efi - 0x09EC31000 [ 3172] ArmCpuDxe.efi - 0x09EC28000 [ 3173] ArmGicDxe.efi - 0x09EC21000 [ 3173] MetronomeDxe.efi - 0x09EC19000 [ 3173] ArmTimerDxe.efi - 0x09EC0F000 [ 3174] SmemDxe.efi - 0x09EBAE000 [ 3174] DALSys.efi - 0x09EBA6000 [ 3175] HWIODxeDriver.efi - 0x09EB9B000 [ 3175] ChipInfo.efi - 0x09EB93000 [ 3175] PlatformInfoDxeDriver.efi - 0x09EB86000 [ 3175] HALIOMMU.efi - 0x09EB72000 [ 3175] ULogDxe.efi - 0x09EB6A000 [ 3176] CmdDbDxe.efi - 0x09EB62000 [ 3176] PwrUtilsDxe.efi - 0x09EB50000 [ 3176] NpaDxe.efi - 0x09EB40000 [ 3177] RpmhDxe.efi - 0x09EB34000 [ 3177] VcsDxe.efi - 0x09EB05000 [ 3178] ClockDxe.efi >>> Cluster 0: 1497600000 Hz >>> Cluster 2: 1248000000 Hz - 0x09EAF8000 [ 3186] ICBDxe.efi - 0x09EAEF000 [ 3188] ShmBridgeDxeLA.efi - 0x09EAE0000 [ 3189] ScmDxeLA.efi - 0x09EAD5000 [ 3191] DiskIoDxe.efi - 0x09EAC8000 [ 3191] PartitionDxe.efi - 0x09EAC0000 [ 3191] EnglishDxe.efi - 0x09E782000 [ 3192] FvSimpleFileSystem.efi - 0x09E761000 [ 3192] UFSDxe.efi UFS INQUIRY ID: MICRON MT512GAXAT8U31 0102 UFS Boot LUN: 1 - 0x09D230000 [ 3220] Fat.efi - 0x09D221000 [ 3221] TzDxeLA.efi - 0x09D190000 [ 3223] VariableDxe.efi LoadSecureApps: Load app from partition(tzxflattest): Status = 0x0, AppId = 2 <VariablePolicyInitialize:179> variable policy engine disabled - 0x09E401000 [ 3437] QcomWDogDxe.efi HW Wdog Setting from PCD : Disabled - 0x09CF5D000 [ 3438] ResetRuntimeDxe.efi - 0x09CF55000 [ 3439] XGAdcDxe.efi - 0x09E409000 [ 3439] WatchdogTimer.efi - 0x09CF3A000 [ 3439] SecurityStubDxe.efi - 0x09CF4D000 [ 3440] EmbeddedMonotonicCounter.efi - 0x09CF66000 [ 3441] RealTimeClock.efi - 0x09CF13000 [ 3441] DevicePathDxe.efi - 0x09CF29000 [ 3441] CapsuleRuntimeDxe.efi - 0x09CECC000 [ 3442] HiiDatabase.efi - 0x09CF31000 [ 3442] FontDxe.efi - 0x09CDDF000 [ 3447] QcomBds.efi - 0x09CE99000 [ 3455] VerifiedBootDxe.efi - 0x09CEB9000 [ 3456] DALTLMM.efi - 0x09CEC2000 [ 3456] I2C.efi - 0x09CE73000 [ 3457] SPMI.efi - 0x09CDBC000 [ 3461] PmicDxe.efi PM0: 47, PM1: 48, PM2: 49, PM3: 50, PM4: 51, app_pshold_cfg change: DVDD_SHUTDOWN -> NORMAL_SHUTDOWN Module cannot re-initialize DAL module environment - 0x09CE23000 [ 3485] SdccDxe.efi - 0x09CE47000 [ 3486] DDRInfoDxe.efi - 0x09CE3F000 [ 3489] FeatureEnablerDxe.efi QseeResponse->result = 0xFFFFFFFF Status = 0x7 QseeResponse->result = 0xFFFFFFFF Status = 0x7 Image partition label not found EFI_QseecomStartApp: Load from partition (featenabler_a)Failed: Status(0x800000000000000E), appId(0) QseeResponse->result = 0xFFFFFFFF Status = 0x7 QseeResponse->result = 0xFFFFFFFF Status = 0x7 Image partition label not found EFI_QseecomStartApp: Load from partition (featenabler)Failed: Status(0x800000000000000E), appId(0) Image partition label not found LoadImageFromPartitionUsingGuid Failed: 14 EFI_QseecomStartApp: Load Failed: Status(0x800000000000000E) Failed to start featenabler_a TA, status = 14 - 0x09CD17000 [ 3493] DisplayDxe.efi - 0x09CD97000 [ 3494] FvDxe.efi - 0x09CDB3000 [ 3495] PILProxyDxe.efi - 0x09CCFB000 [ 3495] PILDxe.efi pil-abl Done t=87ms s=1ms a=45ms f=38ms - 0x09CD7E000 [ 3668] SPSSDxe.efi SPSSDxe [spss_iar_main] I: IAR-STATE is NOT ACTIVATED [0x0], Exit now Overriding PIL cfg by caller pil-SPSS Failed to get MDT size pil-SPSS Failed to load metadata pil-SPSS Failed to boot subsys SPSSDxe:: SPSSDxe_LoadSPSS ProcessPilImageExt = Load Error Error: Image at 0009CD7E000 start failed: Load Error - 0x09CD7D000 [ 3678] IPCCDxe.efi - 0x09CCAC000 [ 3679] GlinkDxe.efi smem_alloc_ex: SMEM alloc_ex failed with err=-3! smem_type=478, remote=13, size=32, flags=0x40000000. - 0x09CD75000 [ 3680] PrintDxe.efi - 0x09CCA2000 [ 3680] SPI.efi - 0x09CD69000 [ 3681] PmicGlinkDxe.efi - 0x09CC8D000 [ 3681] UsbPwrCtrlDxe.efi - 0x09CC4E000 [ 3682] QcomChargerDxeLA.efi QcomChargerDxe:: ChargerPlatform_Init Enabled WDOG. - 0x09CC85000 [ 3702] ChargerExDxe.efi - 0x09CC1B000 [ 3703] UsbfnDwc3Dxe.efi - 0x09CC97000 [ 3704] XhciPciEmulation.efi - 0x09CC37000 [ 3704] XhciDxe.efi - 0x09CC09000 [ 3705] UsbBusDxe.efi - 0x09CBFC000 [ 3705] UsbKbDxe.efi - 0x09CBF0000 [ 3706] UsbMassStorageDxe.efi - 0x09CBD9000 [ 3706] UsbConfigDxe.efi InitUsbClocks: ClockProtocol unavailable UsbConfigLibOpenProtocols: PMI version (0x30) UsbConfigLibOpenProtocols: PMI version (0x30) UsbConfigInit: Aborting Host Mode Initialization due to dead battery UsbConfigInit: Aborting Host Mode Initialization due to dead battery UsbConfigInit: UsbPwrCtrl No. of Ports = 1 UsbConfigPortsQueryConnectionChange: usbport->connectstate: ATT HandlePortPartnerXtach: Cable Attach core 0, portmode 1, dualmode 1 - 0x09CC70000 [ 3714] ButtonsDxe.efi ButtonsDxeTest: Keypress SDAM data payload 4 - 0x09CBB6000 [ 3715] CPRDxe.efi - 0x09CB8B000 [ 3735] GpiDxe.efi - 0x09CA3B000 [ 3833] UCDxe.efi - 0x09CB83000 [ 3839] RngDxe.efi - 0x09CB7B000 [ 3840] SimpleTextInOutSerial.efi - 0x09CA6D000 [ 3841] ConPlatformDxe.efi - 0x09CA2D000 [ 3842] ConSplitterDxe.efi - 0x09CA21000 [ 3843] GraphicsConsoleDxe.efi - 0x09CA17000 [ 3844] ASN1X509Dxe.efi - 0x09CA0D000 [ 3844] SecRSADxe.efi - 0x09CA77000 [ 3845] XResetReasonDxe.efi PonReason in PMIC_PON 0x85 invalid header for PMON_HISrestore RST_STAT 0x00000003 - 0x09CA01000 [ 3845] TaDxe.efi - 0x09C9F9000 [ 3846] XOemCertDxe.efi - 0x09C9EE000 [ 3846] XBootPALDxe.efi - 0x09C9E6000 [ 3847] XProductIdDxe.efi - 0x09C9DA000 [ 3848] UdonDxe.efi - 0x09C9B9000 [ 3848] XGraphicImagesDxe.efi - 0x09C9B1000 [ 3919] XPmicAccessDxe.efi - 0x09C9A9000 [ 3920] ResetCfgDxe.efi - 0x09C9CA000 [ 3920] MinidumpTADxe.efi smem_get_addr: SMEM get addr failed! smem_type=628MinidumpTADxe: Minidump TA loading not enabled. Error: Image at 0009C9CA000 start failed: Load Error - 0x09C9A1000 [ 3925] TsensDxe.efi - 0x09C986000 [ 3928] UsbMsdDxe.efi - 0x09C979000 [ 3929] UsbDeviceDxe.efi - 0x09C971000 [ 3929] UsbInitDxe.efi - 0x09C968000 [ 3930] ParserDxe.efi - 0x09C961000 [ 3931] SerialPortDxe.efi BDS Entry [ 3931] Disp init wait [ 3931] rtc raw 5931 ----------------------------- Platform Init [ 3944] BDS Boot Cycle : 18408 Run Cycle : 18408 UEFI Ver : 6.0.210916.BOOT.MXF.1.0-00589-LAHAINA-2 Platform : MTP Subtype : 0 Boot Device : UFS Chip Name : SM_LAHAINA Chip Ver : 2.1 Chip Serial Number : 0x3DD46605 Boot Core : 1497 MHz ----------------------------- - 0x09C916000 [ 3963] QcomChargerApp.efi QcomChargerDxe:: ChargerPlatform_ChkChgFwLoadRequired Chg Fw Load not required boot to HLOS ChargerLib:: no Turn Off LED UEFI Total : 862 ms POST Time [ 3968] OS Loader - 0x09C7B0000 [ 3972] LinuxLoader.efi Loader Build Info: Sep 16 2021 10:32:41 QseeResponse->result = 0xFFFFFFFF Status = 0x7 VB: RWDeviceState: Succeed using rpmb! Boot counter is 18651 XBoot Init Init XBootPALAPILib Init TA API Lib XBOOT (1322-1669_X_Boot_SM8350_LA1.0_R_31) Reading 325 bytes from RPMB, OK Reading 325 bytes from RPMB, OK XBoot MakeDecisions Check authenticated commands [ERROR @ ta_interface.c:343]: Unable to delete TA unit 2334 Make Decisions PBA ID: V5034977A (1) Vendor(0x00000000)->Sony(0x00000000) Setting existing handle Startup flags: [USB INSERTED] Warmboot reason: [COLDBOOT] [ERROR @ sony_boot_config_parser.c:740]: None or incorrect vbus_pulse configuration! Fastboot service trigger detected Service mode detected: [FASTBOOT] Collect command line additions Obtain backlight config Verify OEM unlock flag Request Generate authenticated channel nonce Booting Into Fastboot Enable XHwreset S2 reset is enabled Setting existing handle Erased Rddata Partition Size = 201000 Total DDR Size: 0x00000002F7500000 Launching fastboot Fastboot Build Info: Sep 16 2021 10:32:39 UsbStartController: Starting Core 0 in mode: 4 UsbStartController: GetUsbAlwaysConnect failed on Core 14: Success SSUsb1InitCommon: gNpaClientSS1Bus is NULL) usb2_rcal: 10 platform: 8 usb_shared_hs_phy_init: hs phy cfg size: 12 usb_shared_ss_phy_init: ss phy cfg size: 155 ssusb_phy_init_success_lane_B: 1 ConfigUsb: CoreNum 0, Mode 4, USB_INIT_DONE 1 Fastboot: Initializing... Fastboot: Processing commands FastbootInitialize: 413: Vbus=1 UsbfnDwcCoreCableStatus: Cable Attached Dev_Common_Speed: Dev Bus Speed: High, state 2 Handling Cmd: reboot-bootloader Rebooting the device into bootloader mode INFO: Received ResetSytem request. INFO: Type :0x0 INFO: DataSize :0x19 INFO: String :RESET_PARAM Length: 0x18 Start EBS [17092] UsbfnDwcCoreCableStatus: Cable Detached BDS: LogFs sync skipped, Unsupported |
