Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 01-26-2015, 06:53   #1 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
Unhappy cant flash nexus 5
helo cant flash nexus 5 d821 32gb
no idea for nexus flashing try 1 time what is my mistake
i have all reday download factory image file v.hammerhead lrx210...lrx22c...ktu84p...ktu84q...and unrar this but find only image file where is flash-all script. bootloader, baseband firmware(s), and operating system file??
how can find this all necessary bootloader, baseband firmware(s), and operating system???
i have tryed flashing with lg flash tool dll and tot file phone flashing 6% and error masege user data erase failed...
try hard reset aafter bootloder unlock formating erase ok cache failed and bilnking logo
phone codnition google logo and swich off
fastboot done
bootloder unlock done
help plz..........................
Old 01-26-2015, 09:25   #2 (permalink)
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
plz help need help............................
Old 01-26-2015, 10:10   #3 (permalink)
Crazy Poster
Member: 2320241
Thanks Meter: 7
Nexus 5 Android 5.0 Lollipop
http://r7---sn-h557sn7y.c.android.cl...422263192&mv=m
Recovery mode
./adb sideload [OTA file].zip
Old 01-27-2015, 07:54   #4 (permalink)
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
plz send full command.....................
Old 01-27-2015, 08:13   #5 (permalink)
czaren's Avatar
Member: 735013
Thanks Meter: 74
all the file you have downloaded must be copied/pasted in platform folder in ADB.if you still dont have ADB, download it.I assumed you have, just run the flash.all (batch file) inside the platform folder and it will do the rest.
Unlocked Bootloader is required.
But if you downloaded a factory image only without the flash.all script
You need to put all the factory image also inside the platform folder in ADB and manually flash it.
fastboot flash bootloader C:/image-hammerhead-krt16m/bootloader.img
fastboot reboot-bootloader
fastboot flash radio C:/image-hammerhead-krt16m/radio.img
fastboot flash system C:/image-hammerhead-krt16m/system.img
fastboot flash userdata C:/image-hammerhead-krt16m/userdata.img
fastboot flash boot C:/image-hammerhead-krt16m/boot.img
fastboot flash recovery C:/image-hammerhead-krt16m/recovery.img
fastboot erase cache
then wipe in recovery.
The Following User Says Thank You to czaren For This Useful Post:
Old 01-28-2015, 08:54   #6 (permalink)
Crazy Poster
Member: 2320241
Thanks Meter: 7
boot UNLOCKING
Now that you can connect to your Nexus device from your computer it's time to unlock your bootloader. To do this you must first boot into your bootloader. You can either manually turn off your phone or tablet and hold down the power button and the volume down button to enter your device's Bootloader Menu or you can enter the following commands into your terminal or command prompt.
Run the following command to make sure your device is properly connected to your computer. If it returns a string of characters it means that you are all set to start updating your device.
./adb devices
Now to enter into the Bootloader menu just run the following command.
./adb reboot bootloader
At the bottom of the screen there will be several things listed including the lock state of the device. This should say locked unless you have unlocked your bootloader in the past and never went back and locked it again.
Now to unlock your bootloader, which is required only when flashing a stock firmware image (not sideloading and update, which we'll get to soon), you must enter the below commands. Remember that when unlocking your Nexus' bootloader it will factory reset your device, so you will lose everything stored on it. If you have not yet backed up anything important on your device you can hit the power button while Start is highlighted in the Bootloader menu and this will boot you back into your device like normal. Now back to unlocking your bootloader.
./fastboot oem unlock
A dialog will appear on the device asking if you are sure about unlocking. Again this will factory reset your device, so if you want to back out of the process you just need to select no with the power button. If you are ready to unlock your bootloader you press the volume up button and then the power button to confirm that you wish to unlock your bootloader.
./fastboot reboot-bootloader
It is recommended to reboot the bootloader just to give itself a check to make sure everything is working correctly before moving onto the next step.
Old 01-28-2015, 08:57   #7 (permalink)
Crazy Poster
Member: 2320241
Thanks Meter: 7
Flashing an ota update
When it comes to getting official Android updates, Nexus devices almost always win the race but that does not mean the updates roll out fast enough for Nexus owners. With every update there are two different types of files that become available for the different Nexus devices — the factory image that is a clean, fresh build of Android, and the OTA (over the air) update file that is sent to all the different Nexus phones and tablets on the market.
Once the OTAs start rolling out to consumers it is very common for someone to find the file's download path and pull the update .zip file. These can be found almost immediately online. Once you have the OTA file we recommend you backup your device's data just in case something goes wrong in the update process, but this process will generally not wipe your device unless done incorrectly.
Just as is the case with the factory image update, put the OTA file in the Platform Tools directory to simplify the process of sending the file to your phone.
First, make sure that your computer is communicating correctly with your Nexus phone or tablet. As long as your device's serial number comes back as a connected device you are ready to begin updating your device.
./adb devices
Next, put your device into the bootloader menu by either the following command or by holding down the power button and the volume down button while your Nexus is turned off.
Now use the volume down button twice until you have scrolled to Recovery mode, and press the power button to select it. It will look like your Nexus is restarting itself but an image of an Android with a red exclamation mark over it will appear. Next hold down the power button and press the volume up button, and you will be in recovery mode.
Now that you are in the Android system recovery, use the volume down button to highlight apply update from ADB and press the power button to select it. The text on your Nexus' screen will now say that you can send the OTA to the device using adb.
In your terminal or command prompt you will see dialog that shows you the progress of transferring the update to your phone or tablet and once it has been completely transferred you can read what is happening with the update live on screen. Again, once the process is done your Nexus device will restart itself and attempt to boot normally. You have successfully updated your Nexus!
Old 06-26-2017, 14:24   #8 (permalink)
Member: 2647618
Thanks Meter: 18
Exclamation
Can you post me data bro?? one link what is hier is a recovery pack iam bricked.. working only fastboot.. NO LG UP detection NO LG TOOL DETECTION,, THX
Page generated in 0.19049 seconds with 8 queries
