Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 10-28-2013, 10:37   #16 (permalink)
Member: 2023019
Sonork: 100.1640918
Thanks Meter: 16
Originally Posted by johnn28 View Post
I have tried all ways of hard reseting this ph and still no joy please help !!
and the ph is locked in Enter Security code stage .
Hi,
YOU CAN USE Furious Gold or Vyges Box.
The Following User Says Thank You to ovunlock For This Useful Post:
Old 10-28-2013, 10:45   #17 (permalink)
Member: 2023019
Sonork: 100.1640918
Thanks Meter: 16
Originally Posted by GSM_Naseer View Post
how to hard reset Lg f120l plzzzzzzzzzzzzz
Turn off the phone.
Press and hold both Volume down + HOME + Search buttons + POWER on your LG Optimus 4G LTE phone.
Factory reset wipe data.
Old 10-28-2013, 10:56   #18 (permalink)
Member: 2023019
Sonork: 100.1640918
Thanks Meter: 16
Originally Posted by niduhassaan View Post
how to hard reset lg f320 s.the fone is locked with pettren lock
Hi,
You can hard resert wtih SRSRoot for Android. its very good sevice for Andriod
Gr,
Old 10-28-2013, 16:05   #19 (permalink)
Member: 1814409
Sonork: 100.1621741
Thanks Meter: 25
how to hard reset Lg f120kplzzzzzzzzzzzzz
Old 10-29-2013, 09:14   #20 (permalink)
Member: 2053477
Originally Posted by ovunlock View Post
Hi,
Thanks I will how and where do i start ... oh and now my computer wont recognise the drivers of the Phone ?
Old 10-29-2013, 21:49   #21 (permalink)
Member: 2053477
or help me flash it as ive tried these methods and they dont work ?
As this is new to me Do i have to Purchase anything to make either of these Programs to work ?
Old 11-05-2013, 12:44   #22 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
do flash the phone ..........
Old 11-05-2013, 18:31   #23 (permalink)
Member: 2053477
Still no luck can you help with a process to fix please
Old 11-13-2013, 00:05   #24 (permalink)
Member: 2064256
how can i unlock my pattern lock security after my son was playing with it...pliz help...LG ku9500 cyon
Old 12-07-2013, 01:57   #25 (permalink)
Member: 1339076
Thanks Meter: 30
how to lg optimus vu f100l hard reset pls help
Old 12-25-2013, 15:36   #26 (permalink)
Member: 1717964
lg gt 540 hardreset solution pls
Old 12-26-2013, 03:44   #27 (permalink)
Member: 1270451
Thanks Meter: 4
Hard Reset LG E-435 (android) via ADB
This LG E-435 can't be reset by any Button combination
First you will need:
1. Driver Quallcom
2. Adb
So, Here how to do it:
1. Install Driver
2. Extract ADB. Copy files AdbWinApi.dll & adb.exe to C:\Windows\System32
3. Turn Off Phone & Go to Recovery Mode. Hold down Volume UP + Power. Release All Buttons after LG Logo Appears
4. Connect Phone ke PC. Wait until all Drivers installed
5. Open Command Prompt
6. Type: adb reboot recovery
7. Phone will reboot couples time, It will display LG Logo > Green Robot > LG Logo
8. Wait until Welcome Screen displayed
9. Done
if you need Original Image Size before resize. Download Here
Hope it Help... Thanks
The Following User Says Thank You to squallvai For This Useful Post:
Old 12-26-2013, 09:28   #28 (permalink)
Member: 2053477
will this work on My GW300 cause when i hold down the power and the Vol up i have no luck ?
Old 01-30-2014, 18:54   #29 (permalink)
Member: 1143287
Sonork: 100.1662982
Thanks Meter: 4
LG F120L Successfuly Hardreset
I am Allready LG F120L Successfuly Hardreseted
(Volium + Volium -) + (Power Switch) hold and press and when come startup logo relese power switch untill press both volium switch wait and see when back startup logo relese volium switch then come Reset menu
Old 01-31-2014, 11:42   #30 (permalink)
Super Moderator
GSMWorld's Avatar
Member: 16
Sonork: 100.1652085 GSMWorld
Thanks Meter: 1,743
LG KU5400 Hard Reset / Factory Reset
Warning: This will remove ALL data on the phone (but not the MicroSD card)
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone.
__________________
Wbr
GSMWorld
Page generated in 0.26856 seconds with 9 queries
