LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
01-02-2016, 01:32 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2509372 Status: Offline Thanks Meter: 0 | lg g3 screen unresponsive after touch firmware upgrade For the last two days I tried everything I can, so I'll try to explain every move I made. First of all, I tried every version from kitkat to lollipop, even I flashed the marshmallow update, but no success. ATM I am on lollipop stock rom, with root and TWRP recovery. I am using my mouse through usb adapter to navigate with the phone. I rooted my phone with kingroot app. - The touch screen firmware version on my phone is -1, that was the case even before my screen got unresponsive, I can't figure it out how is this possible. I tried doing the same thing, updating the touch screen firmware but nothing happens when I click update through the service menu. - I opened the back of the phone, reconnected the screen with the motherboard and turned on the phone - but no success. The situation remains the same. unresponsive screen. So I am kindly asking for any advice or idea you have about my problem, how can I get my phone to work properly? Does someone know where can I find a working touchscreen firmware for LG G3 D855? Is it possible to push the firmware to my phone using adb sideload or twrp? At last, can a screen replacement solve this issue? I am 100% sure that this is not a hardware problem, all I need is to push a touch screen firmware on my phone. Please help! |
08-31-2016, 16:06 | #2 (permalink) | |
Junior Member Join Date: Nov 2015
Member: 2486025 Status: Offline Thanks Meter: 0 | Quote:
09-06-2016, 01:38 | #3 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | It is the issue of your touch IC firmware. There is a chip in lcd or in touch panel called touch ic it's have its own firmware to handle the phone's touch firmware. Try to upgrade the touch firmware again or contact me may be I help you Otherwise changing the screen will 100% solve this issue Br, Shahzaib Jahangir #Zaibis |
10-15-2016, 13:42 | #4 (permalink) | |
Junior Member Join Date: Oct 2009
Member: 1143614 Status: Offline Thanks Meter: 5 | Quote:
Already tried downgrade to 5.1 and upgrade to 6.0 but it is the same. Info about touch firmware version : ======== Firmware Info ========== ic_fw_version RAW = 30 05 51 86 === ic_fw_version info === Innotek 0key Synaptics 5.5 PanelType 1 version: v1.06 IC_product_id[PLG313] Touch IC: s3528(family_id=0, fw_rev=0) img_fw_version RAW = 30 05 51 86 === img_fw_version info === Innotek 0key Synaptics 5.5 PanelType 1 version: v1.06 Img_product_id[PLG313] Touch IC: s3528(family_id=0, fw_rev=0) Is there anything I could do to solve this problem ( without changing LCD+Touch assembly ) ? | |
10-16-2016, 04:46 | #5 (permalink) |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | It seems that the software of your phone's touch IC is ok I think that it is a hardware issue you need to change the touch or the whole panel (touch and lcd) First try to change touch only Sent from my Fire Phone using Tapatalk |
10-18-2016, 01:13 | #7 (permalink) |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | I think there is only one chance without changing lcd or touch You have to change the touch flexy You just corrupted the touch IC's firmware that what I do with S4 by doing this after changing flexy it was ok but after some day the lcd was gone 😂 Sent from my Fire Phone using Tapatalk |
10-18-2016, 01:25 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Syria ♪♫ Tartus Age: 47
Member: 299401 Status: Offline Sonork: facebook:Ahmad Majzoub Thanks Meter: 233 | is a hardware issue by touch side but its software problem cause you try other version flash file .. its not compatible with it . |
