LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
03-22-2018, 17:15 | #4 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | Or if you got greyed usb debugging in service menu try this new solution should work. Is long but should solve your problem. Google Account Verification bypass LG Android 7.x security patch 2018 by HardReset.info team |
03-24-2018, 02:27 | #5 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 241855 Status: Offline Sonork: 1623913 Thanks Meter: 89 | Quote:
03-26-2018, 05:47 | #6 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2483193 Status: Offline Thanks Meter: 5 | lg v30 bypass frp https://www.youtube.com/watch?v=XParzYXisKI&t=340s try this video ..is caind of complicated but it works .. i just did it with my tmobile v30 h932 |
03-26-2018, 20:52 | #7 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Quote:
Not work , fingerprint and security not active in step 2 | |
04-11-2018, 15:36 | #10 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2824106 Status: Offline Thanks Meter: 0 | Lg v30 frp bypass Spent several hours to figure this **** out. Worked for my t-mobile phone, don't know if it still works after the new software update. Don't pay for the solution it's wasted money No time or equipment to make a video out of it so here are the steps. 1. Go to accessibility amd emable switch access. 2. Restart device. 3. Upon startup the switch access menu will pop up and you can see the top bar, pull it down and go to settings from the gear symbol. 4. Connect to wifi, go to cloud -> add account -> dropbox and chrome will open. 5. Go download shortcutmaster apk file. (for later) 6. Go to maps (through chrome or storage from the i symbol in the notification section) and search for anything you can get a telephone number and open it with the "call" option. 7. Erase the number and type in *#*#759#*#* -> RLZ Debug UI and enable OEM option. 8. Go back to settings, then storage, downloads, install and open apk file (enable unknown sources). Connect phone to pc via cable. 9. Go to three dots and search for usb, then find usb options and tap launch, this should bring you to a menu, choose the MTP option and check if the phone shows up at your screen. 10. After that repeat step 6. but now type *#546368#*XXX# - Replace the XXX with model number, go to SVC then LDB and enable USB debugging, a window will show up on the screen to confirm the debugging action. 11. Download adb and fastboot application on your computer, install and open (unfortunately I am not allowed to post links yet) 12. Type in adb devices, press enter 13. Type in adb shell content insert --uri co-ntent://settings/secure --bind name:s:user_setup_complete --bind value:s:1, then press enter 14. Go to welcome screen fly through the setup skipping everything, the homescreen will popup, go to settings, security, deactivate the find my phone option, go to about phone, software, tap on build number until you become developer, allow OEM unlock, go to backup and reset and factory data reset. Hopefully after that you can have a functional device or you will be stuck to a network-locked/blocked t-mobile device like myself not having money to pay a third party service to unlock it This was the solution for my device, maybe it can work with other models. Last edited by marxb; 04-11-2018 at 15:43. |
