Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 10-30-2017, 06:23   #91 (permalink)
abdul.majid8186's Avatar
Member: 2582370
Sonork: 100.1675531
Thanks Meter: 126
Please Help..
Please Need LG G4 H810 Files
Old 10-30-2017, 06:51   #92 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,714
Try with This:-
H810 Fix By QFIL.zip
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Old 10-31-2017, 11:08   #93 (permalink)
Member: 2773487
h812 brick any solution >>
Old 11-04-2017, 19:16   #94 (permalink)
Member: 1739390
Sonork: 100.1623876
Thanks Meter: 5
please want LS995 boot repair files
these links are dropped
---------------thanks
Old 11-06-2017, 06:15   #95 (permalink)
Member: 1739390
Sonork: 100.1623876
Thanks Meter: 5
I have ls995 soft bricked
Start Download
Program Path:C:\Users\Aziz\Desktop\LS991_ARB_02_RecoveryIm age\prog_emmc_firehose_8992_lite.mbn
COM Port number:55
Sahara Connecting ...
Sahara Version:2
Start Sending Programmer
Sending Programmer Finished
Switch To FireHose
Max Payload Size to Target:49152 Bytes
Device Type:eMMC
Platform:8x26
Disable Ack Raw Data Every N Packets
Ack Raw Data:False
Skip Write:False
Always Validate:False
Use Verbose:False
COM Port number:55
Sending NOP
NOP: Fail Code: 10
Unable to send FireHose NOP, Device is not in Firehose mode !
Download Fail:System.Exception: Failed to send Firehose NOP to the phone.
at QC.QMSLPhone.Phone.QPHONEMS_FireHoseNOP()
at QC.SwDownloadDLL.SwDownload.FireHoseDownloadImage( Boolean bResetPhone, List`1 rawprogramFilesList, List`1 patchFilesList, Single& fImageSizeInMB, Single& fThroughput)
Download Fail:FireHose Fail FireHose Fail
Finish Download
I tried all of the fils in these models but not succeed
can you help by the correct file for LS995 please
Old 11-08-2017, 13:57   #96 (permalink)
Member: 243551
Thanks Meter: 24
i have LS991 after flash and another model. qfil not flash. i am tried flash witout testpoint. cm2 failed too.
Validating Application Configuration
Load APP Configuration
COM:90
SAHARA:True
SAHARA:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn
SEARCHPATH:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage
RAWPROGRAM:
rawprogram0.xml
PATCH:
patch0.xml
ACKRAWDATAEVERYNUMPACKETS:False
ACKRAWDATAEVERYNUMPACKETS:100
MAXPAYLOADSIZETOTARGETINBYTES:False
MAXPAYLOADSIZETOTARGETINBYTES:49152
DEVICETYPE:eMMC
PLATFORM:8x26
READBACKMODE:0
RESETAFTERDOWNLOAD:False
MAXDIGESTTABLESIZE:8192
SWITCHTOFIREHOSETIMEOUT:30
RESETTIMEOUT:200
RESETDELAYTIME:2
METABUILD:G:\GSM1\SE\e6653\APP-SW_Sumire_GLOBAL-LTE2A_32.3.A.2.33_1295-7444_S1-SW-LIVE-F936-PID1-0006-MBR\boot\boot_delivery.xml
FLATBUILDPATH:C:\
FLATBUILDFORCEOVERRIDE:True
QCNPATH:C:\Temp\00000000.qcn
QCNAUTOBACKUPRESTORE:False
SPCCODE:000000
ENABLEMULTISIM:False
Load ARG Configuration
Process Index:0
Validating Download Configuration
Image Search Path: G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage
RAWPROGRAM file path: G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\rawprogram0.xml
PATCH file path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\patch0.xml
Programmer Path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn
Meta Build Content XML Path: G:\GSM1\SE\e6653\APP-SW_Sumire_GLOBAL-LTE2A_32.3.A.2.33_1295-7444_S1-SW-LIVE-F936-PID1-0006-MBR\boot\boot_delivery.xml
Fail to load contents.xml: В документе XML (1, 2) присутствует ошибка.
Start Download
Program Path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn
COM Port number:90
Sahara Version:2
Switch To FireHose
Wait for 3 seconds...
Device Type:eMMC
Platform:8x26
Skip Write:False
Use Verbose:False
COM Port number:90
Sending NOP
ReadFile last error: 995
Response is NULL
NOP: Fail Code: 14
Download Fail:FireHose Fail Failed to send Firehose NOP to the phone.
Finish Download
Old 11-18-2017, 07:31   #97 (permalink)
Member: 2779962
I'm keep getting this while trying to unbrick LG G4 LS991
Download Fail: FireHose Fail FireHose Fail: Failed to send Firehose NOP to the phone.
Problem History:
My LG G4 LS991 got into Qualcomm HS-USB QDLoader 9008 mode while i was trying to flash it. and whenever i connect it to pc, the mobile is being detected as Qualcomm HS-USB QDLoader 9008 by itself.
Is there any solution for this? i'd much appreciate your help.
Old 11-19-2017, 01:53   #98 (permalink)
Member: 2001933
Thanks Meter: 2
Someone unbrick H810 version? I tried with QFIL but always I get FireHose Fail. When I connect with USB is shown like QDLoader 9008 mode.
Some news for this?
Sent from my iPhone using Tapatalk
Old 11-19-2017, 11:38   #99 (permalink)
Member: 2779962
[QUOTE=...:::SHAMIM:::...;12434128][CENTER][CENTER][B][FONT=Tahoma][U]Unbrick LG G4 Brick hs-usb Qdloader 9008
Problem History:
Old 11-19-2017, 16:43   #100 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,714
[QUOTE=SKS007;12792079]
Problem History:
Don't Think Every Qualcomm HS-USB QDLoader 9008 mode comes from Downgrade or wrong firmware flashed!
Most Of Phone faulty by eMMC Problem!
The thread of Solution Only for Who did Downgrade or Wrong Firmware Flashed by His Self. He can Try it. Otherwise Rehot, Replace eMMC by Hardware.
Try to Check Your Phone by Hardware.
__________________
__________________
Best Regards,
Shamim
Old 12-16-2017, 11:19   #101 (permalink)
Member: 149814
Please Help LG G4 H812 , i need the files for QFIL
The Following User Says Thank You to chronicforever For This Useful Post:
Old 12-19-2017, 18:26   #102 (permalink)
bendou's Avatar
Member: 165971
Thanks Meter: 65
please share QPST.WIN.2.7-00430-GENERAL
Old 12-21-2017, 10:01   #103 (permalink)
bendou's Avatar
Member: 165971
Thanks Meter: 65
please any help need this file
Old 01-04-2018, 23:20   #104 (permalink)
Member: 2796368
lg g4 h815 unbrick 9008
this failure massage appear on "qfile". is reason because you not have correct "firehose program.
The Following User Says Thank You to tolk2tm For This Useful Post:
Old 01-08-2018, 12:34   #105 (permalink)
Member: 2108317
Thanks Meter: 4
H815 hard-brick after downgrade for mistake
COM:-1
SAHARA:True
SAHARA:C:\Users\Admin\Desktop\H815_Recovery\H815_R ecovery\H815_ForFusingDevice\prog_emmc_firehose_89 92_lite.mbn
SEARCHPATH:C:\Users\Admin\Desktop\H815_Recovery\H8 15_Recovery\H815_ForFusingDevice
RAWPROGRAM:
rawprogram0.xml
PATCH:
patch0.xml
DEVICETYPE:eMMC
PLATFORM:8x26
READBACKMODE:0
RESETTIMEOUT:200
RESETDELAYTIME:2
FLATBUILDPATH:C:\
SPCCODE:000000
Process Index:0
Image Search Path: C:\Users\Admin\Desktop\H815_Recovery\H815_Recovery \H815_ForFusingDevice
RAWPROGRAM file path: C:\Users\Admin\Desktop\H815_Recovery\H815_Recovery \H815_ForFusingDevice\rawprogram0.xml
PATCH file path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\patch0.xml
Programmer Path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\prog_emmc_firehose_8992 _lite.mbn
Start Download
Program Path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\prog_emmc_firehose_8992 _lite.mbn
COM Port number:4
Sahara Version:0
Download Fail:Unable to download Flash Programmer using Sahara Protocol
Download Fail:Sahara FailSahara Fail
Finish Download
Page generated in 0.21418 seconds with 9 queries
