03-06-2015, 05:56 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1005456 Status: Offline Thanks Meter: 39 | Mt6571/Mt6572 Sptool solution if still Dead after Complete Flashing And when you try to flash on Sptool it stop on 4%.. Or even the flashing is completed the phone is still dead. But there is some Co-tech here in the Ph found the Solution to make it continue on Flashing in Sptool and dont stop in 4%.. In Sptool there is what so Called Advanced mode Setiings.. NOTE: NOt All Mt6571/mt6572 Chipset Support by Sptool on Format All + Download yuore device will Brick on this Method of Flashing.. Much better to use Donwload only or the Firmware Uprade settings this settings will not killl youre phone.. Here is the trick of Sptool Mt6571 to make it countiue again in flashing. Open Sptool and go to Format Tab and press on keyboard Ctrl Alt V and choose format whole flash and forecedly Erase (Bad blocks mark is erased) Go to options and choose Download and put check PhysicalFormat/readback And back to Format Tab and Click start and after erasing flash youre phone and Set Sptool on Download only Big Credits to to those Tech here in Ph who discovered and share this trick to us: rievax VIOLA.... Last edited by rievax; 03-06-2015 at 06:04. |
The Following 4 Users Say Thank You to rievax For This Useful Post: |
03-06-2015, 07:28 | #2 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Thanks for this share could you please tell me which version in sptool more compatible for this type of chip and next time when get so many bad blocks error i try this and post here Last edited by blacky199; 03-06-2015 at 07:35. |
The Following User Says Thank You to blacky199 For This Useful Post: |
08-11-2015, 17:12 | #4 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2057725 Status: Offline Thanks Meter: 1 | Hello. Instead of CTRL+ALT+V, I did SHIFT+ALT+V and formatted all. Then I flashed the GT-s7562 mt6572 By bakar (on 4shared to download). and then Miracle, my Mtk Phone revived after more than one year in coma. Thank you very much for your help, I´ve tried all before. Sorry for my bad englich, I speak french and german. |
The Following User Says Thank You to momon68 For This Useful Post: |
02-25-2017, 16:19 | #7 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Rawalakot Age: 35
Member: 1591198 Status: Offline Thanks Meter: 28 | one big problem when you put firmware the format option disabled I try all tricks but advance bad blocks format option not shows I think sp tool team fix this update in next update all gsm master give us solution please how to visible advance bad bolck format option |
03-02-2017, 07:34 | #10 (permalink) | |
Member: 1591198 Status: Offline Thanks Meter: 28 | Bad block format option Quote:
Brother when i put scatter file the format option disable please help how to enable the option again | |
03-03-2017, 11:15 | #12 (permalink) |
Member: 1591198 Status: Offline Thanks Meter: 28 | Sir i use latest ver i use ctrl+alt+v the bad block option enable when i force to farmat the mobile software says that use the scatter file when i put the file the format option disable i use again alt+ctrl+v but the no option return |
