09-02-2013, 15:20 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | [MT6575/6577/MT6572/MT6582/6589]MTK Android Based Phone IMEI Write Tool IMEI&SN Writer 100000% Working & Tested With MT6572 & MT6582 Download DB File for MT6572, MT6575, MT657 & MT6589 Download from here 4shared folder - DB file MT6582 DB File Is Here Warning Only For Repair Original IMEI Br, azam |
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post: |
09-23-2013, 14:00 | #7 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Write IMEI: WriteIMEI_1: 911202151313301 WriteIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS It is over !! sir after write ok , phone restart again and imei goes same as old one ,mt6572 |
09-26-2013, 14:47 | #11 (permalink) |
Insane Poster Join Date: Apr 2008 Age: 34
Member: 739546 Status: Offline Thanks Meter: 15 | Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta Fail: It is over !! MT 6589 imei write failed |
09-28-2013, 11:30 | #13 (permalink) |
Freak Poster Join Date: May 2005 Location: Philippines Age: 42
Member: 144777 Status: Offline Sonork: 100.111515 Thanks Meter: 100 | works perfect for mtk 6577 model: skk a5 Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Write IMEI: WriteIMEI_1: 359310045241189 WriteIMEI_2: 359310045241197 WriteIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS It is over !! thanks man!!!..... |
09-29-2013, 10:37 | #14 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | hi thanx for reply all of u guys my s4 i9500 mt6572 problem is solved and my imei is repaired by dis tool and thanx to dat who give me solution this not possible yet on volcano but dis tool make my problem solve so i give dat linkhttp://forum.gsmhosting.com/vbb/f606/mt6572-6575-6577-6589-mtk-android-based-phone-imei-write-tool-1708731/#thisthis tool repaired imei successfully as u see in below pic even serial no an etc i thanks to nokian care |
09-30-2013, 11:46 | #15 (permalink) |
Freak Poster Join Date: Nov 2011 Location: indonesia
Member: 1695196 Status: Offline Sonork: 100.1623915 Thanks Meter: 509 | mito tab t520 mtk 6577 Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Read SN: ReadSN: MT012345678901234567 Read SN is OK !!! Start Write IMEI: WriteIMEI_1: 111111111111111 WriteIMEI_2: 222222222222222 WriteIMEI is OK !!! Start Read IMEI: ReadIMEI_1: 111111111111111 ReadIMEI_2: 222222222222222 ReadIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS Read BT Address Start: ReadBT: de1246662867 Read BT is OK !!! Read WIFI Address Start: ReadWIFIAddr: 000000000000 Read WIFI Address is OK !!! Read SW Version Start: GetSWVer: ALPS.JB.MP.V1.22 Read SW Version is OK !!! Read Internal SW Version Start: GetSWVer_Internal: GM1503_M10_V1.1 Read Internal SW Version is OK !!! It is over !! |
