Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 09-17-2015, 14:27   #1 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
SOLUTION-MTK 6572 dead in flashing and now flash not take with any tool
3% only flash process and hang
like this
don't worry now u can recover here
1st u need proper virsion flash file
next u need sptool latest virsion
for 6572 i use this SP_Flash_Tool_exe_v3.1344.0.212
open sptool select proper flash file
now press ctr+alt+v on key board u see advnce mode in sptool
now u see in option tick on physically format/readback option
now click on formate option
here u see
1 formate whole flash chip tick on
forcedly Erase (bad block mark is erased
then ok now insert usb without battery without press any key
format start
after formate remove usb and click on start button and insert usb again
now ur flashing start
some time set after flash hang on logo no worry its take 4-5 minuts 1st start
if after 4-5 minuts set still hang then use firmware -upgrade button and start again flash
100% set ok
this solution for MT6572 NAND chip
for 6571 Nand chip next time i post
plz dont ask for EMMC chip this solution not work with it
if u want copy this solution to ur group i dont mind
The Following 19 Users Say Thank You to sneha For This Useful Post:
Old 09-19-2015, 19:55   #2 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Hello
Good tutorial.
can you post to MT6571 Nand ?
Thank you.
mfeliu07
Old 09-22-2015, 12:15   #3 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Originally Posted by mfeliu07 View Post
Hello
Good tutorial.
Thank you.
mfeliu07
yes possible but for 6571 u need this tool
SP-Flash-Tool-v5.1532.00
The Following User Says Thank You to sneha For This Useful Post:
Old 09-22-2015, 12:31   #4 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 207
if set not onnect after format whole flash then open set and find gold point just as kclo and short it to ground .
The Following User Says Thank You to shailccna For This Useful Post:
Old 09-22-2015, 20:49   #5 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Hello
I could solve, I had this phone for over a year broken.
Thank you for your good tutorial.
A note, did not have the Flash toll suggested by you and use SP_Flash_Tool_Windows_v5.1504.00
Thank you so much
mfeliu07
The Following User Says Thank You to mfeliu07 For This Useful Post:
Old 09-23-2015, 05:01   #6 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
@sneha
i do it but erase flag option not found.
Old 09-23-2015, 06:33   #7 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Originally Posted by .::MAHABUB::. View Post
@sneha
if set have emmc chip then this will not work .. its work with only NAND chip
The Following 2 Users Say Thank You to sneha For This Useful Post:
Old 11-27-2015, 09:53   #8 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
for MT6571
use this tool
SP_Flash_Tool_exe_Windows_v5.1516.00
rest all process same like post 1
Old 12-09-2015, 15:31   #9 (permalink)
Member: 2412793
Thanks Meter: 3
brother erase flag area not found in sp flash tool plz help
Old 12-10-2015, 15:24   #10 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
read carefully again this
http://forum.gsmhosting.com/vbb/11294442-post1.html
The Following 4 Users Say Thank You to sneha For This Useful Post:
Old 12-25-2015, 10:23   #11 (permalink)
Member: 1701545
Thanks Meter: 100
intex aqua 3g after whole flash format after flash set is done
thanks sneha ( om bhai )
Old 01-04-2016, 19:18   #12 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
I have y220 u10 nand dead
I try latest spflashtool
And old one
But cant be format without battery
And with battery
But battery is 20%
Shoud be full?
Old 01-04-2016, 19:21   #13 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
And SP_Flash_Tool_Windows_v5.1504.00
Old 01-05-2016, 05:30   #14 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
add screenshot which error u get
Old 01-05-2016, 08:06   #15 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
brom error (4032)
and screen shot
Page generated in 0.30618 seconds with 8 queries
