Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 11-09-2014, 01:10   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Moto G,E Moto G(2nd gen)Moto G LTE Moto X Moto X (2nd gen) Firmware + Flashing guide
Moto G & E Moto G(2nd gen) Moto G LTE Moto X Moto X (2nd gen) Firmware + Flashing guide
Note: Use mfastboot command instead of normal fastboot command
Ex: mfastboot flash boot boot.img
Downloads Required:
Download & install adb fastboot driver Here
Motorola Driver
Mfastboot driver
Firmware Download Here
Alternate Download link here
Note: Files with _umtsds in their names are meant for Dual Sim variants only.
Moto G (XT939G, XT1008, XT1031, XT1032, XT1033, XT1034)
Moto G 2nd Gen (XT1063 / XT1064 / XT1068 / XT1069)
Moto G LTE (XT1039 / XT1040 / XT1045)
Moto X (XT1049, XT1050, XT1052, XT1053, XT1055, XT1056, XT1058, XT1060)
Moto X 2nd Gen (XT1092 / XT1097)
Moto E (XT1021, XT1022, XT1025)
Flashing Guide
Method 1
Download the necessary Firmware File and extract it
Enable USB Debugging Mode. Go-to Settings > Developers Option and Tick the USB debugging
Power Off your device and Open in Bootloader mode.Press nd hold Power + Volume Down button till yu see sme text on screen
Now Open the folder where yu hav extracted the Firmware files nd open cmd there. Hold Shift Key and Right Click anywhere in the folder then Click Open Command Prompt Here
If yur Firmware File has tar.gz extension,
Den type below givn cmmd
flashall.bat /eu
Wait for the Firmware files to be flashed on yur device
den it vil boot
automatically
Now if your Firmware files have xml.zip extension extract nd flash via fastboot
Type Below given cmmds to flash the device
Example For Moto G
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
After al done yur phone will reboot automatically
Method 2
Moto X Flashing via RSD Lite
Download RSD Lite
extract the downloaded firmware nd find a file with .XML extension. Right click on this file nd select Open with..nd then open it using Notepad or any XML editor. Now find the below given string and delete it.
<step operation="getvar" var="max-download-size" />
Save the changes
Cnnt yur mob in bootloader mode(fastboot mode)
Run Rsd lite there select the firmware
Press start
Wait till the firmware is flashed and when it is complete, your phone will reboot
DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 21 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-09-2014, 10:56   #2 (permalink)
Member: 138575
Thanks Meter: 58
Hi,
In the second method of Flashing Using RSD Lite, In The Boot mode, phone is not detected in Software to flash.IOn device manager in that mode, I can see Motorola ADB device. How will it flash.
First method of flashing for me is difficult to understand using command promt, as I always get error "flashall.bat /eu is not recognised as internal or external command, operable program or batch file"
Need HElp to solve this Problem.
jackle123
Old 11-09-2014, 11:38   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
1st install al above drivers
Place the mfastboot driver folder n desktop copy the firmware files also there
Put yur mob n fastboot mode not adb mode
Use win7 os Shift right click n the folder nd select open command window here to run
the command
Den run mfastboot command
nd run Command 1 by 1 (Easy to flash via command try it)
Old 11-09-2014, 12:19   #4 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
I dont want to be too demanding but can you create a PDF of the procedure or guide
thanks again for this great guide
frenzy
Old 11-09-2014, 12:29   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
frenzy
Check tis video
How To Restore Moto G Dual Sim XT1033 To Stock Firmware - YouTube
Old 11-12-2014, 18:03   #6 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 322
thats fine ,,,i got xt-912 at my shop for KITKAT ,,,,is there any download link to download it ?,,,if not is there any custom firmware ? if yes ,,,plz give link and one thing more is writing of custom firmware is same as htc method ,,,means first CWM file in FASTBOOT method ,,then custom file through SD card ?
wating for your kind replies,,deaar james,,,,,,
Old 11-12-2014, 19:54   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
1st Root yur mobile (google it)
Install rom manager from play store
Install cwm recovery using Rom manager
More cwm Recovery Guide & Detail here
4.4 cm Based Custom rom Here
Google Gapps Here
Note: Cm based roms are not stable Before flash custom rom tak backup of yur current rom
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 11-13-2014, 09:47   #8 (permalink)
Member: 566122
Thanks Meter: 322
too confused ,,,,,plz guide i have just downloaded MOTO X firmware ,,,but in download menu showing alot of models,,likMoto X (XT1049, XT1050, XT1052, XT1053, XT1055, XT1056, XT1058, XT1060)e so plz tell me will the file which i have download is Android 4.4.4
Blur_Version.212.55.26.ghost_verizon.Verizon.en.US
my question is ,,will this file ( WHICH IS OF STOCK FIRMWARE ) will work on all above GIVEN MODEL ?
and can i upgrade this file through RSDLITE soft ?
waiting for replies ,,,,
PLZ NOTE THE ABOVE FILE IS FOR MOTO X only not for 2nd GENERATION ,,
Old 11-13-2014, 10:15   #9 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Post yur model nubr nd wic region firmware yu need.
Old 11-13-2014, 10:18   #10 (permalink)
Member: 566122
Thanks Meter: 322
sir my model no is XT-1050 and i need us region file,,,,
Old 11-13-2014, 10:57   #11 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yur file V4.4.2
Downlaod
If yur mob has any issues flash tis firmware using rsd lite
If yu mob has no issues jus update to 4.4.4 via wifi check ota update
Old 11-13-2014, 11:15   #12 (permalink)
Member: 566122
Thanks Meter: 322
good and realy hardworker you are ,,,
Old 11-13-2014, 11:29   #13 (permalink)
Member: 566122
Thanks Meter: 322
Originally Posted by jamesjerss View Post
Yur file V4.4.2
Downlaod
sir one thing plz ,,,,is there any file after extracting to delete ,,,as you have mentioned in your given thread ?
Old 11-13-2014, 11:34   #14 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yes to flash via rsd lite remove tis sting <step operation="getvar" var="max-download-size" />
flashing via fastboot or vit auto bat file no need
Old 11-13-2014, 11:38   #15 (permalink)
Member: 566122
Thanks Meter: 322
I like to flash via FASTBOOT bat ,,,,but a little hard as compare to flash with RSDLITE soft ,,,,a little confusion and cant understand yet to flash via bat ,,,,,however soon will be understand ,,,,,
Page generated in 0.29379 seconds with 9 queries
