Member: 952226
Thanks Meter: 20 | I solved . Change the power ic gazoo and reflash again BEFORE Quote:
image '2nd', size 14720 bytes
valid for rx-51: 2217, 2218, 2219, 2220, 2120
version 1.4.14.9+0m5
image 'xloader', size 14848 bytes
image 'secondary', size 109440 bytes
valid for rx-51: 2101, 2102, 2103
image '2nd', size 14848 bytes
valid for rx-51: 2307, 2308, 2309, 2310
valid for rx-51: 2407, 2408, 2409, 2410
valid for rx-51: 2301, 2302, 2303, 2304, 2305, 2306
valid for rx-51: 2401, 2402, 2403, 2404, 2405, 2406
valid for rx-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2
113, 2114, 2115, 2116, 2117, 2118, 2119
valid for rx-51: 2501, 2502, 2503, 2504, 2505, 2506
valid for rx-51: 2607, 2608, 2609, 2610
valid for rx-51: 2507, 2508, 2509, 2510
valid for rx-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2
210, 2211, 2212, 2213, 2214, 2215, 2216
valid for rx-51: 2601, 2602, 2603, 2604, 2605, 2606
suitable usb device not found, waiting.
Usb device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device rx-51, hardware revision 2204
nolo version 1.4.14
version of 'sw-release': Rx-51_2009se_21.2011.38-1.004_pr_004
sending xloader image (14 kb)...
100% (14 of 0 kb, avg. 14 kb/s)
sending secondary image (106 kb)...
100% (106 of 0 kb, avg. 106 kb/s)
flashing bootloader... Done.
Sending cmt-2nd image (79 kb)...
100% (79 of 0 kb, avg. 79 kb/s)
sending cmt-algo image (507 kb)...
100% (507 of 0 kb, avg. 507 kb/s)
sending cmt-mcusw image (5826 kb)...
100% (5826 of 0 kb, avg. 5826 kb/s)
flashing cmt-mcusw... Done.
Sending kernel image (1705 kb)...
100% (1705 of 0 kb, avg. 1705 kb/s)
flashing kernel... Done.
Sending and flashing rootfs image (185728 kb)...
100% (185728 of 0 kb, avg. 185728 kb/s)
finishing flashing... Done
cmt flashing failed AFTER CHANGE POWER IC
c:\program files\maemo\flasher-3.5>c:\program files\maemo\flasher-3.5
'c:\program' is not recognized as an internal or external command,
operable program or batch file.
C:\program files\maemo\flasher-3.5>flasher-3.5.exe -f rx-51_2009se_21.2011.38-1.
004_pr_combined_004_arm.bin -f -r
flasher v2.5.2 (sep 24 2009)
sw version in image: Rx-51_2009se_21.2011.38-1.004_pr_004
image 'kernel', size 1705 kb
version 2.6.28-20103103+0m5
image 'rootfs', size 185728 kb
version rx-51_2009se_21.2011.38-1.004_pr_004
image 'cmt-2nd', size 81408 bytes
version bb5_09.36
image 'cmt-algo', size 519808 bytes
version bb5_09.36
image 'cmt-mcusw', size 5826 kb
version rx51_icpr82_10w08
105.
nolo version 1.4.14
cmt flashed successfully
