Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here |
03-01-2013, 13:08 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: JUST IMAGINE
Member: 882865 Status: Offline Sonork: 100.1614808 Thanks Meter: 17 | Hard reset for NOKIA windows phones * Hard Reset: Press two keys (Volume down and Power) together. When Handset vibrates, first release the power key and then Volume down. After that Handset will restart. (Consumer Data will not be erased) * Reset your Phone: Go to Start Screen>> Application List>> Settings>> About>> “Reset your phone”. (In this case, Consumer Data will be completely erased) * Phone Update: This feature can be used to update the SW of WP8 devices using Wi-Fi, if any new SW is available. It can done from Start Screen>> Application List>> Settings>> phone update. (For new SW update) * OS Reset: Make Sure the charger is disconnected from Device. 1. Switch the power off. 2.Press and hold the Volume down and connect the charger, if succeed an exclamation mark (!) is shown on the screen. Then press following keys in this order: 1. Volume up 2. Volume down 3. Power 4. Volume down Phone will reset and boot up automatically. Please note that this may take several minutes. (In this case, Consumer Data will be completely erased) Note: Put the Handset on charging for minimum 30 minute, incase of Dead. Attempt 3-4 times for Hard reset, incase Handset is not getting switched on. In the last you should try with OS Reset option, but remember that Data will be erased. Regards, PRABATH.N |
The Following User Says Thank You to nmprabath For This Useful Post: |
