Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 09-10-2012, 09:04   #1 (permalink)
ub
ub's Avatar
Member: 1757379
Sonork: no need
Thanks Meter: 400
Smile Interop-Unlock Lumia 800 plus bootloader and NAND access [Q&A]
Questions & Answers
Q: I've a Lumia 800 or 710 can I Interop-Unlock it?
A: The short answer is yes if you have a Lumia 710 - you must firstly downgrade your bootloader - and "maybe" for the Lumia 800, because only some of them can be Interop-Unlocked at the moment.
Q: I've got a Lumia 710 how can I downgrade my bootloader to the Qualcomm one?
A: Youmust flash Яндекс.Народ
with Nokia Care Suite (mirror splitted in two parts
RM-803.part1.rar
RM-803.part1.rar
Q: Cool how can I discover if I'm a lucky owner or not?
A: For first go to "Settings -> About -> more info" and if your "Hardware revision number" ends with 2.4 you are probably screwed out.
Q: I've got 2.4 hw rev how can I check eventually?
A: You don't need to check if your hw rev is 2.4 and your Lumia came with firmware 11500 or higher you have the new nokia bootloader.
Q: I've got 2.3 hw rev how can I check if I'm eligible?
A: If you've got hw rev 2.3 but you have flashed your device with a firmware 11500 or higher - flashed mean with Nokia Care Suite because Zune doesn't update your bootloader - you have the new Nokia Bootloader; if you want eventually to check see below "check if my device is interop-unlockable".
Q: So at the moment which can be interop-unlocked?
A: As for now can be interop-unlocked hw rev 2.3 with firmware version 11141 or below.
Q: I've got the NOKIA DLOAD can I put the Qualcomm bootloader?
Yes but ONLY if you have a Lumia 710, on the 800 is not possible at the moment.
Q: Can I get the Qualcomm bootloader by downgrading my Lumia ?
No, you can't flash the Qualcomm bootloader with a backup, as
Q: I have interop-unlocked my Lumia but now I can't access Windows Live services!
: You can find your solution
xda-developers - View Single Post - DEV ONLY - NAND access + Full Unlock for Lumia 710 & 800
Q: I've got the NOKIA DLOAD how can I flash my device?
A: You can ONLY flash your device with Nokia Care Suite.
Q: I've got the Qualcomm bootloader how can I flash my device?
A: You can ONLY flash your device with Qualcomm .QPST
The Story so far: Nokia Interop-Unlock plus bootloader and NAND access
Check if my device is Interop-Unlockable
Shut down your device
Hold pushed VOL + and POWER
Plug into your USB, you will hear a short vibration
If you are running Windows it will ask to format an USB drive, say no!
then you can Interop-Unlock your Lumia with one of the following ROM:
Lumia 800: Interop Unlock (no full unlock yet)
ROM based on: RM819_059P453_1600.2487.8107.12070_002
Mediafire folder access:
Lumia 710 interopunlock without apps - test4.part1.rar
Free Cloud Storage - MediaFire
os-new.part2.rar
os-new.part3.rar
os-new.part4.rar
Lumia 710: Interop Unlock (no full unlock yet)
ROM Based on: RM803_059N2L6_1600.3015.8107.12070_010
CAUTION: these images AREN'T TESTED. Use at your own risk.
After that, you'll need to hard reset the phone:
Hold Power button for 10 seconds to exit Qualcomm's disk mode, and press and hold POWER+VOLUMEDOWN+CAMERA until you feel the phone vibrate.
After that, RELEASE power button but KEEP HOLDING volume down + camera for five or more seconds
This will trigger the hard reset.
If when you plug your device and you see NOKIA DLOAD for now your out of luck because your bootloader is locked and you can't flash the roms above.
Lumia 710 & 800 ROMs
Full Unlocked ROM for Nokia Lumia 710
XDA Files - Lumia800/ROM/Zipped
Qualcomm Disk layout
[B]Completed the file uploads:
Dump_in_parts.part*.rar : Dump of the OS partition (IMGFS dump)
Dumpmap-imgfsobjects.zip: logs and stuff from OSBuilder
sd*.rar: compressed DD dumps of the rest of the filesystem
NOT INCLUDED:
Partition #5: contains product code and stuff from phone, 64kb
Partition #4: Extended partition container for partitions 5-9
Partition #9: Cannot post that enormous partition, 15Gb in size (but should be enough with the dumped os).
[COLOR="*****Brown"]LUMIA 800 FLASH FILE SYSTEM LAYOUT:[/COLOR]
Partition Begin End Blocks ID
/dev/sdb1 * 1 1000 500 4d Initial Bootloader - SECBOOT
/dev/sdb2 1001 4000 1500 46 Second stage loader? - OSBL, also looks like it has the download mode and seems to init LCD, enable USB etc.
/dev/sdb3 4001 304000 150000 c W95 FAT32 (LBA) - Writable partition with EMMCBOOT, AMSS etc.
EMMCBoot is responsible for loading Windows Kernel (nk.exe). I got a copy of Samsung Galaxy i9001's emmcboot.mbn, and putted it in there. It tries to start, but seems to crash (expected). But hey! it tries to boot it (it even vibrates for 1/10 of a second), so getting something else (did anyone say...android?)running on this phone should be easier than in lots of other phones... Does anyone have u-boot ports for Qualcomm 8255?
/dev/sdb4 304001 31037579 15366789+ 5 Extended partition which holds the OS
/dev/sdb5 304006 304133 64 ef EFI (FAT-12/16/32) - Linux detects it as an EFI partition, but it's just 64Kb size, and seems to have some markers, not sure yet what it is, but could be anything from IMEI and simlock to an actual efi partiton for WinCE...
EDIT AGAIN: this partition contains phone serial number and product code, and possibly imei and simlock. For sure its not an efi partition
/dev/sdb6 304134 310277 3072 58 3Mb size
/dev/sdb7 393216 399359 3072 4a 3Mb size
/dev/sdb8 399360 405503 3072 4b 3Mb size
These three partitions have similar start and end data on their partitions, no idea what they are, since I haven't been able to see if it's even a file system. All the documentation I see seems to tell Windows Mobile uses exFAT for the filesystem, but can't seem to find its header anywhere on the flash... still looking. It could even be where WinMo stores application installers for first boot on the device (but could be perfectly wrong)
All of them start with the following header (hex):
7D 8D 27 82 D7 40 F8 90 53 22 82 43 6D EC 6F 69 49
/dev/sdb9 524288 31156362 15316037+ 48
This las partition is 15Gb size, and contains all the Operating System and all the data on the phone.
Anyone know about how does Windows Phone manage filesystems on NAND? Some help would be really appreciated...
The file system for the 15Gb partition has _wmstore header, still incompatible with some kitchens, but still looking...
Here's part of the header:
_wmstore
!zLH?k
_wmpart_B
_wmpart_S
_wmpart_S
_wmpart_N
_wmpart_U
_wmpart_D
_wmpart_I
_wmpart_P
_wmpart_U
PSBdX
GFCB
SRPX
LK Bootloader for Lumia
https://github.com/beidl/lk_umia
*** Compiling the LK Android bootloader ***
** Tested on Ubuntu 11.10 with Lumia 710 **
1) Get the toolchain and install:
wget https://sourcery.mentor.com/public/g...ux-gnu.tar.bz2
sudo tar xvf arm-2009q1-203-arm-none-linux-gnueabi-i686-pc-linux-gnu.tar.bz2 --directory /opt/
2) Compile the bootloader:
PATH=/opt/arm-2009q1/bin:$PATH TOOLCHAIN_PREFIX=arm-none-linux-gnueabi- PROJECT=msm7630_surf make EMMC_BOOT=1
3) Get your Lumia into diagnostics mode (turn it on using VOL UP + VOL DOWN + POWER)
4) BACKUP EVERY SINGLE FILE FROM THE 150MB PARTITION! (Just to be safe)
5) Replace the image/emmcboot.mbn file with your freshly compiled LK bootloader
cp <repo dir>/build-msm7630_surf/EMMCBOOT.MBN /media/<mount point>/image2/emmcboot.mbn
6) Unmount the bootloader partition from your PC and pull the phone's battery
7) Turn on, wait a few moments, and plug the phone to the PC
8) Test the fastboot connection:
fastboot devices
fastboot getvar version
for now is working only the fastboot protocol but nothing more, is in current alpha stage.
br:
ub
The Following 2 Users Say Thank You to ub For This Useful Post:
Page generated in 2.66386 seconds with 8 queries
