Airbag Clearing crash data, servicing airbags |
10-27-2008, 22:55 | #46 (permalink) |
Junior Member Join Date: Jan 2003 Location: Croatia, KC
Member: 20204 Status: Offline Thanks Meter: 3 | [email protected] Thanks in advance |
The Following User Says Thank You to Dodo2 For This Useful Post: |
10-28-2008, 07:05 | #47 (permalink) |
Major Poster Join Date: Feb 2008 Location: Croatia PU
Member: 700438 Status: Offline Thanks Meter: 13 | Hi, I have same dumps too if we can create something for common share. I will apriciated link to this 12MB dunps too. I think to build workbench (universal) for testing SRS units on workbench is anybody know where we can find SRS pinouts? I am using Autodata 3.18 but it is not covored for most models. Regards, |
The Following User Says Thank You to tihiuvek For This Useful Post: |
10-28-2008, 07:17 | #48 (permalink) |
Member: 700438 Status: Offline Thanks Meter: 13 | Hi spider-man, You wrote "As i alway's taught where is airbag sensor located in car ? do you have a picture for this ?" My suggestion to you (i am using) is to find AutoData DVD collection. There is a lot of different places (depand by vehicle) where the sensor's are stored (pluriel soory for my grammer). Sure it can help. It is the same for ECU, ABS, AC and other specific devices. I buld workbench for ECU's but is quite difficul to connect (improvising connectors for all ECU's). Changing of resistance for same sensors like Temp sensor, Tortle posution, O2 sensor (generator) and it is not very precise. Offten after reparation you have to clear all DTC dirrectly on vehicle. Differance when you cleaning SRS which belongs directly to the vehicle -you just have to test Crash sensors, replace airbag with specific resistance (do not tray to measure by Ohm meter because it can be dangerous)., Belt tension system has small activation bomb (same procedure as before). If all is OK than remowe and connect all. |
The Following 2 Users Say Thank You to tihiuvek For This Useful Post: |
10-29-2008, 22:56 | #49 (permalink) |
Junior Member Join Date: Oct 2008
Member: 887410 Status: Offline Thanks Meter: 1 | Can anybody send me the download link for Tachosoft 15.4 ,AirBag Resetter 4 and Licznik 4.5 on PM? [email protected] Thanks |
The Following User Says Thank You to 00007 For This Useful Post: |
11-01-2008, 22:13 | #58 (permalink) |
Member: 20204 Status: Offline Thanks Meter: 3 | I'm still looking for the download link for Tachosoft 15.4, AirBag Resetter 4, Licznik 4.5.... On PM, please [email protected] Is it really possible that nobody have that link, or can't upload software and share a link |
Airbag Resetter 3.0 | decodering | Airbag | 32 | 07-13-2009 21:12 |
Tachosoft airbag resetter | tomitomass | Airbag | 54 | 10-16-2008 00:12 |
Tachosoft Airbag Resetter 3.0 | sixpack | Airbag | 1 | 09-26-2008 18:01 |
