Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics > ECU & IMMO
ECU & IMMO Diagnostic, Immobilizer, Chip Tuning
Old 12-29-2017, 18:29   #1 (permalink)
Member: 430612
Thanks Meter: 301
Car diagnostics tool
Please I need advice want to enter this field I am good on cellphone software but which model to buy
Old 12-29-2017, 18:41   #2 (permalink)
Moderator
shooting@orange's Avatar
Member: 469145
Thanks Meter: 5,153
For diagnostics you need an ELM327, this will do most cars
wbr
The Following 4 Users Say Thank You to shooting@orange For This Useful Post:
Old 12-30-2017, 13:05   #3 (permalink)
Member: 430612
Thanks Meter: 301
wbr
Thanks man this work with laptop? I check they look like adapter
Old 12-30-2017, 13:07   #4 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
Yes, it comes as a USB cable or Bluetooth dongle, both for the PC
wbr
Old 01-06-2018, 07:08   #5 (permalink)
Member: 626711
Thanks Meter: 111
best divice launch easy diag 2.0
Old 01-14-2018, 10:44   #6 (permalink)
Member: 478535
Thanks Meter: 433
You could also get a delphi (good quality nec chip) for as cheap as 150€.
This will do most cars and trucks with stable information! With this interface you can use delphi, autocom and Wurth wow programs. This last wurth wow is so complete that also brings integrated a kind of autodata, with repair instructions for many common maintenance services!
Get also Vag vcds 17 for as cheap as 60€ (quality cable), only for Vag group (seat, vw, etc) to deal with module coding, dct read/erase, etc!
Fiatecuscan for fiat, alfa romeo, etc for a similar price!
BMW INPA K CAN for BMW, mini cooper, etc. This cable you can use with PC and With android app (with otg cable and android device that support OTG as nexus 7 2013) to code BMW, mini cooper for also a similar price.
Canclip for Renault - this one is more expensive (a bit more expensive than delphi) but very usefull for renault, dacia, etc.
Delphi is a generic box to deal mostly with ecu dct errors, but can also code injectors, align steering whell, restart service lights, etc.
But for a more precise functions, you need cables that deal with each group.
Also, don't start just imediatly with ECU tunning, as this is somehow complicated and you can enter in hundreds of euros expenses by damaging ECU's. You will need to read a lot on how programs like winols works, how to deal with egr off, dpf off, give car more torque, hp, etc using fgtech galetto, mpps cable, kess/ktag to read/write dumps.
Good Luck starting you car repair/diagnostic business!
The Following User Says Thank You to Desirat For This Useful Post:
Old 02-18-2018, 17:12   #7 (permalink)
Member: 387971
Thanks Meter: 64
wbr
Do you recommend any software for PC or android ??
Old 02-18-2018, 18:48   #8 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
Software comes with the cable
wbr
The Following User Says Thank You to shooting@orange For This Useful Post:
Old 02-21-2018, 15:04   #9 (permalink)
Member: 387971
Thanks Meter: 64
I have elm327.I did not get any sw with elm327.I found some sw on google but nothing special.
thanks
Old 02-21-2018, 15:46   #10 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
thanks
Use PCMSCAN, it's rather good
wbr
The Following 2 Users Say Thank You to shooting@orange For This Useful Post:
Old 08-14-2018, 15:44   #11 (permalink)
Member: 2511554
Sonork: 100.1671270
Thanks Meter: 11
For BMW i have K-DCAN cable with ISTA+ and ISTAP software. Works like charme.
Old 03-15-2019, 07:12   #12 (permalink)
Member: 2495336
for simple diagnosis,choose a ELM327 or other obd2 scanner.
it enough for your need
The Following User Says Thank You to Engineer Chasen For This Useful Post:
Old 03-15-2019, 15:37   #13 (permalink)
Member: 2849642
Thanks Meter: 12
So based on Your needs I'll give You the following piece of advice:
1- If Your needs are all about just diagnosis and erasing DTC then You'd go with an ELM327 based chip (better be a quality/genuine one) and for the software then I'd rather You to go with (ScanMaster-ELM) for about 59 Euros for only the software.
2- If You considering using tool for advanced functions such as ( ABS bleeding- Throttle adaptation - ECU Coding/Prgoramming) and so then like Desirat said Your resort will be either Delphi (DS150E) Multidiag Pro+ and You can also keep the following tool in mind which is actia multidi@g china clone interface, it's a (J2534 PassThru) based interface and no matter what software year is that (VCI) made for as You can get the 2011 Version for cheap (almost 159$) and then You can have it upgraded to 2017 - 2018 version using a debugging tool for a hex file dump, You can also have it reworked to be faster, more stable and safe to use in case of using for programming.
this particular (VCI) as I mentioned earlier a (J2534 PassThru) based one so You can Rely on it in using many other software that are specific for each manufacturer such as (Toyota techstream - Nissan Consult III Plus - Honda HDS - JLR software for Jaguar and Landrover - GM GDS - GM TIS2000) and the list goes on.
Hope this can help You.
Old 03-22-2019, 04:37   #14 (permalink)
Member: 2495336
you also can buy a obd2 scanner that can run the software on you mobile phone.
like launch easydiag,xtuner e3 x5,iobd2....
Old 03-23-2019, 07:59   #15 (permalink)
Member: 2481830
hi,Which one is worth buying? I saw several different ones. This makes me confused. *******/2Ot7KJX
Page generated in 0.22395 seconds with 8 queries
