ECU & IMMO Diagnostic, Immobilizer, Chip Tuning |
02-05-2010, 18:42 | #1 (permalink) |
Junior Member Join Date: Feb 2010 Location: Athens, Greece
Member: 1227944 Status: Offline Thanks Meter: 0 | VAG COM repair, HELP !!! yesterday I was reading a closed thread in http://forum.gsmhosting.com/vbb/showthread.php?t=675534 I will open it again here, as I own the following VAG COM cables: 1 damaged VAG COM 704.1 2-3 damaged VAG COM 805.1 (software 805.0 came with cd, supplier sent me software for 805.1 by e-mail) 1 damaged VAG COM 805.3 (I think) or 812.4. Most possible is that it is 812.4, I will have to check it again. I remember software works until April 2009. Then you must change system date. I can provide for all of you - F R E E -, GOOD WORKING dumps for the above cables, to fix your CABLES, but I need your help to fix my cables, as I don't know how to start with MProg. I sell these cables, so I have some NEVER OPENED cables. Must I read the .ept of a working cable? How I can do this? The problem is that in 805, activation is lost. I installed in other laptops again the software of 704.1, it found the cable OK, but never does the activation. The other case is that the 704.1 cable is not recognized. I give the right path for the driver but doesn't continue. Yesterday, I opened to see it, but I don't see any 93c46 Atmel chip. I tried to fix it using VAG COM revival, but doesn't see the cable in Windows. Mprog also refers that no device is found, (or something like that). Do I have to desolder the chip, or just programm it from USB port? Thank you, please help me, and I will provide you free good dumps for your cables. Best regards. Last edited by DimitrisH; 02-05-2010 at 18:51. |
Need Vag com usb hex schematics | Ionel | ECU & IMMO | 58 | 10-10-2010 20:35 |
Vag com help | aeroyas | ECU & IMMO | 4 | 01-18-2010 10:00 |
Repair your vag-com 704.1 step by step | fantomel | ECU & IMMO | 81 | 01-04-2010 13:06 |
Vag-com help | novaspace | ECU & IMMO | 16 | 07-26-2009 12:22 |
Vag-Com 704.1 to VCDS 805.0 | dfi2K5 | ECU & IMMO | 76 | 04-16-2009 21:23 |
