HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
09-26-2011, 21:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | i think it look simular to iphone 4 like this : http://www.gzmglobal.com/product_ima...64834_zoom.jpg and contacts are simular then it should work , i will risk one flex cable from iphone 4 for noise reduction mic , i have also one desire and will let you know |
09-26-2011, 21:49 | #3 (permalink) |
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | it is not working , i just managed to fix it with a microphone from sony ericsson k550 (nadji neku k550-ku i zavrsices posao ) |
11-22-2011, 15:45 | #6 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1693875 Status: Offline Thanks Meter: 0 | I assume the mic is supposed to be located just next to the usb port, on the bottom side of the board? I got this board from eBay and it has had some rework done, perhaps it was removed? Pulling my hair out trying to find it... |
01-20-2012, 08:21 | #7 (permalink) |
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | yes it is on bottom side , near usb port , smal golden one ... if you cant find it , means somebody already took it out...find replacement , from SE-k550 |
03-22-2012, 00:26 | #8 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | desire no sound no microphone ht desire after microphone installation worked for 1 hour then no mic or sound no sound from speaker or headphone jack any help pleeze cant find schematicsor diagrams for htc desire thanxx |
12-10-2012, 00:36 | #10 (permalink) |
Freak Poster Join Date: Nov 2005 Location: UK
Member: 196365 Status: Offline Thanks Meter: 35 | small update: to get best quality exactly as original, please use R=0,7k and mic have to be at 1k resistance. as example I used mic at 1,7k resistance and was very very quiet. |
11-26-2014, 12:34 | #12 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2300032 Status: Offline Thanks Meter: 0 | HTC Desire HD...mic swap out This is quite an old post, but...I am sitting at my desk with a Desire HD in pieces following a mic failure...I have a new mic and thought that I would check the resistance across the tabs before attempting a swap out. My fluke cant actually measure anything across the pads as shown in the diagram posted previously...I think I should be able to measure around 1k ?, but I have nothing except a short between two of the pads and the case of the mic...Is the 1k resistance external to the mic?...and also, how do you solder this in when you have no access to the pads as they are situated on the underside of the mic? ...Thanks |
Motorola 7389 - microphone not work. NEED HELP | snk | Motorola Old Legacy (EMMI) | 0 | 04-13-2002 06:07 |
x35 microphone problem | platy | Hardware Repair by brands | 8 | 03-06-2002 03:46 |
3310 microphone does not works | Corban | Nokia Hardware & Hardware Repair | 5 | 01-29-2002 15:11 |
T20 (T28/29) Microphones wanted !!!!!!!!!!!!!!!! | N/East Unlocker | Main Sales Section | 5 | 01-24-2002 20:32 |
motorola V 3690 microphone | maclu | Motorola Hardware Repair | 0 | 12-23-2001 19:09 |
