05-20-2019, 23:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st WORLD Condor Allure A100 DATA RECOVERED DONE VIA eMMC 1st WORLD Condor Allure A100 DATA RECOVERED DONE VIA eMMC with the Greatest OCTOPLUS LOG : Code: Welcome to Octoplus Pro JTAG Software version 1.7.6. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC CWBD3R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010043574244335202151DB2EA820B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CWBD3R Product revision : 0.2 Product serial number : (hex) 151DB2EA Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 5881856 Device Manufacturer :condor Device Platform :mt6795 Build ID :LMY47I Display Build ID :PGN607 Release ID :5.1 Device Model :PGN607 Device Name :PGN607 Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :full_gionee6795_lwt_l1-user 5.1 LMY47I 1439267902 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CWBD3R_20_05_2019_22_22_46.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: secro (0001E900, 00003000) 6 MB P10: para (00021900, 00000400) 512 KB P11: logo (00021D00, 00004000) 8 MB P12: frp (00025D00, 00000800) 1024 KB P13: expdb (00026500, 00005000) 10 MB P14: tee1 (0002B500, 00002800) 5 MB P15: tee2 (0002DD00, 00006300) 12.38 MB P16: system (00034000, 0059C000) 2872 MB P17: cache (005D0000, 000D4000) 424 MB P18: userdata (006A4000, 06DCFC00) 54.91 GB P19: flashinfo (07473C00, 00008000) 16 MB |
The Following 2 Users Say Thank You to starkrimes For This Useful Post: |
