12-09-2020, 21:17 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | 1st World Condor Plume L3 Plus [SP-637] Repair VIA EMMC 1st World Condor Plume L3 Plus [SP-637] Repair VIA eMMC Code: Condor Plume L3 Plus [SP-637] Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC GX6BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100475836424D420394939A66C4BB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GX6BMB Product revision : 0.3 Product serial number : (hex) 94939A66 Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GX6BMB_09_12_2020_20_29_34.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.7; FW: 1.24. P00: GPT (00000000, 04000000) 64 MB P01: modem (04000000, 05400000) 84 MB P02: fsc (0C000000, 00000400) 1024 b P03: ssd (0C001000, 00002000) 8 KB P04: sbl1 (0C003000, 00080000) 512 KB P05: sbl1bak (0C083000, 00080000) 512 KB P06: rpm (0C103000, 00080000) 512 KB P07: rpmbak (0C183000, 00080000) 512 KB P08: tz (0C203000, 00200000) 2048 KB P09: tzbak (0C403000, 00200000) 2048 KB P10: devcfg (0C603000, 00040000) 256 KB P11: devcfgbak (0C643000, 00040000) 256 KB P12: dsp (0C683000, 01000000) 16 MB P13: modemst1 (0D683000, 00180000) 1536 KB P14: modemst2 (0D803000, 00180000) 1536 KB P15: DDR (10000000, 00008000) 32 KB P16: fsg (10008000, 00180000) 1536 KB P17: sec (10188000, 00004000) 16 KB P18: splash (14000000, 00B00000) 11 MB P19: aboot (18000000, 00100000) 1024 KB P20: abootbak (18100000, 00100000) 1024 KB P21: boot (18200000, 04000000) 64 MB P22: recovery (1C200000, 04000000) 64 MB P23: devinfo (20200000, 00100000) 1024 KB P24: system (20300000, 100000000) 4 GB P25: vendor (120300000, 40000000) 1024 MB P26: cache (164000000, 18000000) 384 MB P27: persist (17C000000, 02000000) 32 MB P28: misc (17E000000, 00100000) 1024 KB P29: keystore (17E100000, 00080000) 512 KB P30: config (17E180000, 00008000) 32 KB P31: oem (17E188000, 10000000) 256 MB P32: limits (190000000, 00008000) 32 KB P33: mota (194000000, 00080000) 512 KB P34: dip (194080000, 00100000) 1024 KB P35: mdtp (194180000, 02000000) 32 MB P36: syscfg (196180000, 00080000) 512 KB P37: mcfg (196200000, 00400000) 4 MB P38: cmnlib (198000000, 00100000) 1024 KB P39: cmnlibbak (198100000, 00100000) 1024 KB P40: cmnlib64 (198200000, 00100000) 1024 KB P41: cmnlib64bak (198300000, 00100000) 1024 KB P42: keymaster (198400000, 00100000) 1024 KB P43: keymasterbak (198500000, 00100000) 1024 KB P44: apdp (19C000000, 00040000) 256 KB P45: msadp (19C040000, 00040000) 256 KB P46: dpo (19C080000, 00002000) 8 KB P47: logdump (19C082000, 04000000) 64 MB P48: userdata (1A0082000, 5A7B79E00) 22.62 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GX6BMB_modemst1_0x6b418_0xc00_09_12_2020_20_29_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GX6BMB_modemst2_0x6c018_0xc00_09_12_2020_20_29_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GX6BMB_fsg_0x80040_0xc00_09_12_2020_20_29_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1054720 Number of sectors : 8388608 Device Manufacturer : Condor Build ID : OPM1 Display Build ID : SP637_V10.0_20181101 Release ID : 8.1.0 Device Model : Plume L3 Plus Device Name : Plume_L3_Plus Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8937_64-user 8.1.0 OPM1 2475 release-keys --------------------------------------------------------------- |
The Following 2 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
