DZGSM-TEAM | 07-12-2021 10:03 | 1st World Condor Smart TV 43SD520 Repair VIA eMMC 1st World Condor Smart TV 43SD520 Repair VIA eMMC Android TV Version 9.0 Code:
Main Board JUC7.820.00236289 HLS91F J-I-1 Code:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Operations with eMMC restricted(Bus Mode : 1b)
Connecting...
Device : Toshiba eMMC 008G30
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
--------------------------------------------------------------- CID Info
CID : 11010030303847333000814244D72637
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 008G30
Product revision : 0.0
Product serial number : (hex) 814244D7
Manufacturing date : 02/2019
--------------------------------------------------------------- CSD Info
CSD : D02700328F5903FFFFFFFFE7864000A7
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
--------------------------------------------------------------- EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1 (Bus width = 8Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x0A) 00001010
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + High Speed timings in boot operation
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/008G30_12_07_2021_08_22_45.bin. Connect successful.
--------------------------------------------------------------- SW: 2.2.1; FW: 2.00.
Searching Android build info... Not found
--------------------------------------------------------------- http://gsmserver.com/nfs/content/110...forum_head.png http://gsmserver.com/nfs/content/614...pro2-forum.jpg https://i.imgur.com/iWv7KKu.jpg http://www.gsmserver.com/nfs/content/6149/file/lg.pnghttp://www.gsmserver.com/nfs/content...le/samsung.pnghttp://www.gsmserver.com/nfs/content/6149/file/se.png http://www.gsmserver.com/nfs/content...a_facebook.pnghttp://www.gsmserver.com/nfs/content...le/offsite.png |
