06-10-2020, 18:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World OPPO A3s CPH1853 SRF FOR DOWNGRADE & FIX ALL PROBLEMS [IMG]****************************/convkey/2929/akzsnfnbmk8efylzg.jpg?size_id=7[/IMG] GOT A PHONE ON DEAD MODE FROM OTHER REPAIR SHOP AFTER HE WANTED REMOVE A PATTERN LOCK VIA OTHER eMMC TOOL AND THE SOLUTION WAS WITH THE GIANT MEDUSA PRO ALWAYS SRF IS DOWNGRADABLE FILE IS MADE FOR FIXING THOSE PROBLEMS SUCH : 1-DEAD BOOT 2-THE CURRENT IMAGE (BOOT/RECOVERY) HAVE BEEN DESTROYED 3-BOOTLOOP ( HANGING ON LOGO ) 4-CURRUPTED NVM OR IMEI 5-RESET FRP AND PATTERN LOCK WITHOUT DATA LOSS BASED ON PATCH SECURITY LEVEL OF 09/05/2019 I REALLY GOT TIRED FOR MAKING ALL PROBLEMS FIXED BY ONE REPAIR FILE INFO LOG : Code: Selected PIN - CONNECTOR socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s-CPH1853 SRF : C:/Users/STARKRIMES/Desktop/CPH1853/Oppo_A3s-CPH1853_Patch-Security-05-12-2019_eMMC_By_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D42035821A887A513 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) 5821A887 Manufacturing date : 10/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_10_06_2020_15_47_50.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 2.00. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00002000) 4 MB P21: sec (0004E040, 00000020) 16 KB P22: aboot (0004E060, 00000800) 1024 KB P23: abootbak (0004E860, 00000800) 1024 KB P24: modem (0004F060, 00040000) 128 MB P25: dtbo (0008F060, 00004000) 8 MB P26: vbmeta (00093060, 00000080) 64 KB P27: boot (000930E0, 00020000) 64 MB P28: recovery (000B30E0, 00020000) 64 MB P29: devinfo (000D30E0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: log (0017A440, 00020000) 64 MB P38: oem (0019A440, 00000800) 1024 KB P39: limits (0019C000, 00000040) 32 KB P40: mota (001A0000, 00000400) 512 KB P41: dip (001A0400, 00000800) 1024 KB P42: mdtp (001A0C00, 00010000) 32 MB P43: syscfg (001B0C00, 00000400) 512 KB P44: mcfg (001B1000, 00002000) 4 MB P45: lksecapp (001B4000, 00000100) 128 KB P46: cmnlib (001B4100, 00000800) 1024 KB P47: cmnlib64 (001B4900, 00000800) 1024 KB P48: keymaster (001B5100, 00000800) 1024 KB P49: lksecappbak (001B5900, 00000100) 128 KB P50: cmnlibbak (001B5A00, 00000800) 1024 KB P51: cmnlib64bak (001B6200, 00000800) 1024 KB P52: keymasterbak (001B6A00, 00000800) 1024 KB P53: apdp (001B8000, 00000200) 256 KB P54: msadp (001B8200, 00000200) 256 KB P55: dpo (001B8400, 00000010) 8 KB P56: logdump (001B8410, 00020000) 64 MB P57: vm-kystore (001D8410, 00000800) 1024 KB P58: vm-data (001D8C10, 00005000) 10 MB P59: hyp (001E0000, 00004000) 8 MB P60: vm-system (001E4000, 00020000) 64 MB P61: vm-linux (00204000, 00010000) 32 MB P62: system (00214000, 006B4800) 3433 MB P63: vendor (008C8800, 0020FB00) 1055 MB P64: userdata (00ADC000, 01242FDF) 9.131 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst1_0xa028_0xc00_10_06_2020_15_47_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst2_0xac28_0xc00_10_06_2020_15_47_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 2.00. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_fsg_0x4c040_0x2000_10_06_2020_15_47_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.0; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2179072 Number of sectors : 7030784 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20191205.151001 release-keys ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 31602. LOG SMART REPAIR : Code: Repairing from file "C:/Users/STARKRIMES/Desktop/CPH1853/Oppo_A3s-CPH1853_Patch-Security-05-12-2019_eMMC_By_STARKRIMES.srf". Write data verification is enabled. Writing GPT partition... Done. Writing persist partition... Done. Writing opporeserve1 partition... Done. Writing opporeserve2 partition... Done. Writing ssd partition... Done. Writing sbl1 partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing devcfg partition... Done. Writing sbl1bak partition... Done. Writing rpmbak partition... Done. Writing tzbak partition... Done. Writing devcfgbak partition... Done. Writing dsp partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing modem partition... Done. Writing dtbo partition... Done. Writing vbmeta partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing devinfo partition... Done. Writing splash partition... Done. Writing LOGO partition... Done. Writing DRIVER partition... Done. Writing cache partition... Done. Writing misc partition... Done. Writing keystore partition... Done. Writing config partition... Done. Writing log partition... Done. Writing oem partition... Done. Writing limits partition... Done. Writing mota partition... Done. Writing dip partition... Done. Writing mdtp partition... Done. Writing syscfg partition... Done. Writing mcfg partition... Done. Writing lksecapp partition... Done. Writing cmnlib partition... Done. Writing cmnlib64 partition... Done. Writing keymaster partition... Done. Writing lksecappbak partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64bak partition... Done. Writing keymasterbak partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing logdump partition... Done. Writing vm-kystore partition... Done. Writing vm-data partition... Done. Writing hyp partition... Done. Writing vm-system partition... Done. Writing vm-linux partition... Done. Writing system partition... Done. Writing vendor partition... Done. Smart Repair is successfully complete. SW: 2.1.0; FW: 2.00. Disconnected. IMPROVING PHONE BOOT UP : IMPROVING NO FRP : PHONE INFO : OEM UNLOCKED : IMEI : Download MEDUSA PRO II 2.1.1 Software Find out more at: https://medusabox.com/ Download Octoplus PRO JTAG 2.1.1 Software Find out more at: www.octoplusbox.com |
The Following 7 Users Say Thank You to starkrimes For This Useful Post: |
