05-22-2020, 23:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World Wiko RIDGE FAB 4G changing DAMAGED eMMC from 16GB to 64GB Got a handset with Damaged 16GB eMMC ( eMMC won't accept a flash by USB or ISP ) so my solution was try program new eMMC but with big storage 64GB THIS IS ONLY IMPROVING THE POWER OF THE GIANT MEDUSA PRO And here my steps LOG WIKO eMMC INFO : Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Reader #3: Alcor Micro USB Smart Card Reader 3 Loading firmware. Please wait... Done. Selected eMMC interface. Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 8 bits Bus speed : 50 MHz Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48414732650507DF06D0CE329B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) DF06D0CE Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 461920 Number of sectors : 3325952 Device Manufacturer : WIKO Device Platform : msm8916 Build ID : LRX22G Display Build ID : LRX22G release-keys Release ID : 5.0.2 Device Model : RIDGE FAB 4G Device Name : l5320 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : l5320-user 5.0.2 LRX22G eng.android.20171227 Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_22_05_2020_22_38_30.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 00020000) 64 MB P02: sbl1 (00040000, 00000400) 512 KB P03: sbl1bak (00040400, 00000400) 512 KB P04: aboot (00040800, 00000800) 1024 KB P05: abootbak (00041000, 00000800) 1024 KB P06: rpm (00041800, 00000400) 512 KB P07: rpmbak (00041C00, 00000400) 512 KB P08: tz (00042000, 00000400) 512 KB P09: tzbak (00042400, 00000400) 512 KB P10: hyp (00042800, 00000400) 512 KB P11: hypbak (00042C00, 00000400) 512 KB P12: pad (00043000, 00000800) 1024 KB P13: modemst1 (00043800, 00000C00) 1536 KB P14: modemst2 (00044400, 00000C00) 1536 KB P15: misc (00045000, 00000800) 1024 KB P16: fsc (00045800, 00000002) 1024 b P17: ssd (00045802, 00000010) 8 KB P18: splash (00045812, 00005000) 10 MB P19: DDR (00060000, 00000040) 32 KB P20: fsg (00060040, 00000C00) 1536 KB P21: sec (00060C40, 00000020) 16 KB P22: boot (00060C60, 00010000) 32 MB P23: system (00070C60, 0032C000) 1624 MB P24: persist (0039CC60, 00010000) 32 MB P25: cache (003ACC60, 00083000) 262 MB P26: recovery (0042FC60, 00010000) 32 MB P27: keystore (00440000, 00000400) 512 KB P28: config (00440400, 00000040) 32 KB P29: oem (00440440, 00020000) 64 MB P30: userdata (00480000, 018DBFDF) 12.43 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_modemst1_0x43800_0xc00_22_05_2020_22_38_30.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_modemst2_0x44400_0xc00_22_05_2020_22_38_30.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 2.00. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_fsg_0x60040_0xc00_22_05_2020_22_38_30.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.0.9; FW: 2.00. RPMB: Counter of the successful data write requests = 45. LOG NEW eMMC FROM OPPO F1s : Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 8 bits Bus speed : 50 MHz Connecting... Device : Samsung eMMC RC14MB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100524331344D42074E5CC6954341 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RC14MB Product revision : 0.7 Product serial number : (hex) 4E5CC695 Manufacturing date : 04/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 540672 Number of sectors : 6291456 Device Manufacturer : OPPO Device Platform : mt6750 Build ID : LMY47I Display Build ID : A1601EX_11_A.33_170814 Release ID : A1601EX_11_A.33_170814 Device Model : A1601 Device Name : A1601 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6750_15331-user 5.1 LMY47I 1502723706 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RC14MB_22_05_2020_22_39_42.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 2.00. P00: GPT (00000000, 00000040) 32 KB P01: recovery (00000040, 00008000) 16 MB P02: para (00008040, 00000400) 512 KB P03: reserve1 (00008440, 00001000) 2048 KB P04: reserve2 (00009440, 00008000) 16 MB P05: reserve3 (00011440, 00001000) 2048 KB P06: reserve4 (00012440, 00008000) 16 MB P07: oppo_custom (0001A440, 00000800) 1024 KB P08: expdb (0001AC40, 00005000) 10 MB P09: frp (0001FC40, 00000800) 1024 KB P10: nvdata (00020440, 00010000) 32 MB P11: metadata (00030440, 00010000) 32 MB P12: protect1 (00040440, 00004000) 8 MB P13: protect2 (00044440, 00007BC0) 15.47 MB P14: seccfg (0004C000, 00004000) 8 MB P15: oemkeystore (00050000, 00004000) 8 MB P16: proinfo (00054000, 00001800) 3072 KB P17: md1img (00055800, 0000C000) 24 MB P18: md1dsp (00061800, 00002000) 4 MB P19: md1arm7 (00063800, 00001800) 3072 KB P20: md3img (00065000, 00002800) 5 MB P21: nvram (00067800, 00002800) 5 MB P22: lk (0006A000, 00000800) 1024 KB P23: lk2 (0006A800, 00000800) 1024 KB P24: boot (0006B000, 00008000) 16 MB P25: logo (00073000, 00004000) 8 MB P26: tee1 (00077000, 00002800) 5 MB P27: tee2 (00079800, 00002800) 5 MB P28: secro (0007C000, 00003000) 6 MB P29: keystore (0007F000, 00004000) 8 MB P30: reserve_exp1 (00083000, 00001000) 2048 KB P31: system (00084000, 00600000) 3072 MB P32: reserve_exp2 (00684000, 00002000) 4 MB P33: reserve_exp3 (00686000, 00002000) 4 MB P34: cache (00688000, 00080000) 256 MB P35: userdata (00708000, 06D6BFDF) 54.71 GB P36: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RC14MB_nvdata_0x20440_0x10000_22_05_2020_22_39_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.9; FW: 2.00. RPMB: Counter of the successful data write requests = 201. LOG CHANGING BOOT CONFIG FROM MTK TO QUALCOMM : Code: Boot config succesfully changed! Disconnected. LOG FORMATTING eMMC : Code: Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.0.9; FW: 2.00. Disconnected. LOG WRITING EXT CSD : Code: Writing EXT_CSD succesfully complete! Disconnected. LOG CHANGING CID : Code: Changing CID to 90014A48414732650507DF06D0CE329B. Write CID succesfully completed. Disconnected. LOG CHANGING CSD INFO : Code: Write CSD successfully completed. Disconnected. LOG WRITING BOOT 1 & 2 : Code: Switched to boot area partition 1. Opening C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/BOOT1 Hynix eMMC HAG2e_20_05_2020_21_56_58.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.0.9; FW: 2.00. Switched to boot area partition 2. Opening C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/BOOT2 Hynix eMMC HAG2e_20_05_2020_21_56_58.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.0.9; FW: 2.00. LOG WRITING FULL DUMP VIA PARTITION MANAGER : Code: Partition table is found from file C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin. Don't forget to reconnect the device after writing to see changes. Switched to user area. Writting partitions. Please wait... Writing partition GPT from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition modem from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition sbl1 from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition sbl1bak from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition aboot from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition abootbak from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition rpm from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition rpmbak from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition tz from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition tzbak from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition hyp from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition hypbak from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition pad from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition modemst1 from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition modemst2 from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition misc from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition fsc from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition ssd from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition splash from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition DDR from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition fsg from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition sec from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition boot from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition system from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition persist from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition cache from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition recovery from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition keystore from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition config from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition oem from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing partition userdata from C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix eMMC HAG2e_21_05_2020_20_51_14.bin file... Done. Writing is finished. SW: 2.0.9; FW: 2.00. Reconnect the device to see changes. Disconnected. |
05-22-2020, 23:49 | #2 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | LOG WRITING FRESH FLASH STOCK ROM : Code: Selected file: C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/rom/rawprogram_unsparse.xml. Selected file: C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/rom/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition hyp... Done. Writing partition hypbak... Done. Writing partition splash... Done. Writing partition fsg... Done. Writing partition sec... Done. Writing partition boot... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition recovery... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.0.9; FW: 2.00. Disconnected. Download MEDUSA PRO II Software Find out more at: https://medusabox.com/ Download Octoplus PRO JTAG Software Find out more at: www.octoplusbox.com |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
