Member: 1167260
Sonork: 100.1604772 Thanks Meter: 165 | CPH 1831 dead after reset [Answered] i got oppo cph1831 phone for user lock remove.
i dont have even backup because when i try read flash it ask 24 hours to read because its 116gb chip.
so i stop reading flash at system
then just gave reset option and oppo reset
now phone detect as qualcom 9008 mode, not powering on, but still can connect isp pinout and conecting and show android build.
so pls give me if any possible solution bring it back allive customer keep asking phone. Quote:
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Device : Samsung eMMC 3V6CMB
Page size : 512 B
Block size : 512 B
Block count : 244277248
Size : 116.48 GB (119276.00 MB)
CID Info
CID : 150100335636434D42024672C4B84527
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 3V6CMB
Product revision : 0.2
Product serial number : (hex) 4672C4B8
Manufacturing date : 04/2018
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 40706048 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 1ec00000 bytes
Device sector size : 512 bytes
Partition offset : 2129920
Number of sectors : 11010048
Build ID : OPM1.171019.011
Release ID : 8.1.0
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : sdm660_64-user 8.1.0 OPM1.171019.011 eng.root.20191129.165903 release-keys
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_10_03_2020_21_02_34.bin.
Connect successful.
SW: 2.0.6; FW: 1.24.
P00: GPT (00000000, 00000028) 20 KB
P01: oppodycnvbk (00000028, 00005000) 10 MB
P02: oppostanvbk (00005028, 00005000) 10 MB
P03: modemst1 (0000A028, 00001000) 2048 KB
P04: modemst2 (0000B028, 00001000) 2048 KB
P05: persist (0000C028, 00010000) 32 MB
P06: opporeserve1 (0001C028, 00004000) 8 MB
P07: opporeserve2 (00020028, 00020000) 64 MB
P08: carrier (00040028, 00004000) 8 MB
P09: xbl (00048000, 00001C00) 3584 KB
P10: xblbak (00049C00, 00001C00) 3584 KB
P11: tz (0004B800, 00002000) 4 MB
P12: tzbak (0004D800, 00002000) 4 MB
P13: rpm (0004F800, 00000400) 512 KB
P14: rpmbak (0004FC00, 00000400) 512 KB
P15: hyp (00050000, 00000400) 512 KB
P16: hypbak (00050400, 00000400) 512 KB
P17: pmic (00050800, 00000400) 512 KB
P18: pmicbak (00050C00, 00000400) 512 KB
P19: fsg (00051000, 00001000) 2048 KB
P20: boot (00054000, 00020000) 64 MB
P21: bootbak (00074000, 00020000) 64 MB
P22: recovery (00094000, 00020000) 64 MB
P23: keymaster (000B4000, 00000800) 1024 KB
P24: keymasterbak (000B4800, 00000800) 1024 KB
P25: cmnlib (000B5000, 00000800) 1024 KB
P26: cmnlib64 (000B5800, 00000800) 1024 KB
P27: cmnlibbak (000B6000, 00000800) 1024 KB
P28: cmnlib64bak (000B6800, 00000800) 1024 KB
P29: mdtpsecapp (000B7000, 00002000) 4 MB
P30: mdtpsecappbak (000B9000, 00002000) 4 MB
P31: mdtp (000BB000, 00010000) 32 MB
P32: mdtpbak (000CB000, 00010000) 32 MB
P33: dsp (000DB000, 00008000) 16 MB
P34: dspbak (000E3000, 00008000) 16 MB
P35: abl (000EB000, 00000800) 1024 KB
P36: ablbak (000EB800, 00000800) 1024 KB
P37: dip (000EC000, 00000800) 1024 KB
P38: devinfo (000EC800, 00000008) 4 KB
P39: apdp (000EC808, 00000200) 256 KB
P40: msadp (000ECA08, 00000200) 256 KB
P41: dpo (000ECC08, 00000002) 1024 b
P42: splash (000ECC10, 00010520) 32.64 MB
P43: limits (000FD130, 00000008) 4 KB
P44: toolsfv (000FD138, 00000800) 1024 KB
P45: logfs (00100000, 00004000) 8 MB
P46: ddr (00104000, 00000800) 1024 KB
P47: sec (00104800, 00000020) 16 KB
P48: bluetooth (00104820, 00000800) 1024 KB
P49: bluetoothbak (00105020, 00000800) 1024 KB
P50: fsc (00108000, 00000002) 1024 b
P51: ssd (00108008, 00000010) 8 KB
P52: misc (00108018, 00000800) 1024 KB
P53: keystore (00108818, 00000400) 512 KB
P54: devcfg (00108C18, 00000800) 1024 KB
P55: devcfgbak (00109418, 00000800) 1024 KB
P56: frp (00109C18, 00000400) 512 KB
P57: logdump (0010A018, 00020000) 64 MB
P58: sti (0012A018, 00001000) 2048 KB
P59: LOGO (0012B018, 00008000) 16 MB
P60: DRIVER (00133018, 00010000) 32 MB
P61: vbmeta (00144000, 00000080) 64 KB
P62: vbmetabak (00144080, 00000080) 64 KB
P63: modem (00144100, 00040000) 128 MB
P64: cache (00188000, 00080000) 256 MB
P65: system (00208000, 00A80000) 5.25 GB
P66: vendor (00C88000, 00300000) 1536 MB
P67: odm (00F88000, 00080000) 256 MB
P68: storsec (01008000, 00000100) 128 KB
P69: userdata (0100C000, 0D8E9FDF) 108.5 GB
Backuping modemst1 partition...
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst1_0xa028_0x1000_10_03_2020_21_02_34. bin file...
Reading. Please wait... Done.
Elapsed time 00:00:01
Backuping modemst2 partition...
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst2_0xb028_0x1000_10_03_2020_21_02_34. bin file...
Backuping fsg partition...
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_fsg_0x51000_0x1000_10_03_2020_21_02_34.bin file...
Save to I:/Samsung eMMC 3V6CMB_10_03_2020__21_02_50.mpt file...
Reading partition GPT... Done.
Reading partition oppodycnvbk... Done.
Reading partition oppostanvbk... Done.
Reading partition modemst1... Done.
Reading partition modemst2... Done.
Reading partition persist... Done.
Reading partition opporeserve1... Done.
Reading partition opporeserve2... Done.
Reading partition carrier... Done.
Reading partition xbl... Done.
Reading partition xblbak... Done.
Reading partition tz... Done.
Reading partition tzbak... Done.
Reading partition rpm... Done.
Reading partition rpmbak... Done.
Reading partition hyp... Done.
Reading partition hypbak... Done.
Reading partition pmic... Done.
Reading partition pmicbak... Done.
Reading partition fsg... Done.
Reading partition boot... Done.
Reading partition bootbak... Done.
Reading partition recovery... Done.
Reading partition keymaster... Done.
Reading partition keymasterbak... Done.
Reading partition cmnlib... Done.
Reading partition cmnlib64... Done.
Reading partition cmnlibbak... Done.
Reading partition cmnlib64bak... Done.
Reading partition mdtpsecapp... Done.
Reading partition mdtpsecappbak... Done.
Reading partition mdtp... Done.
Reading partition mdtpbak... Done.
Reading partition dsp... Done.
Reading partition dspbak... Done.
Reading partition abl... Done.
Reading partition ablbak... Done.
Reading partition dip... Done.
Reading partition devinfo... Done.
Reading partition apdp... Done.
Reading partition msadp... Done.
Reading partition dpo... Done.
Reading partition splash... Done.
Reading partition limits... Done.
Reading partition toolsfv... Done.
Reading partition logfs... Done.
Reading partition ddr... Done.
Reading partition sec... Done.
Reading partition bluetooth... Done.
Reading partition bluetoothbak... Done.
Reading partition fsc... Done.
Reading partition ssd... Done.
Reading partition misc... Done.
Reading partition keystore... Done.
Reading partition devcfg... Done.
Reading partition devcfgbak... Done.
Reading partition frp... Done.
Reading partition logdump... Done.
Reading partition sti... Done.
Reading partition LOGO... Done.
Reading partition DRIVER... Done.
Reading partition vbmeta... Done.
Reading partition vbmetabak... Done.
Reading partition modem... Done.
Reading partition cache... Done.
Reading partition system... Done.
Reading is canceled.
Disconnected.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_10_03_2020_21_59_02.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_10_03_2020_21_59_07.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_10_03_2020_21_59_19.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Release ID : 8.1.0
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_10_03_2020_21_59_29.bin.
Connect successful.
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst1_0xa028_0x1000_10_03_2020_21_59_29. bin file...
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst2_0xb028_0x1000_10_03_2020_21_59_29. bin file...
Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_fsg_0x51000_0x1000_10_03_2020_21_59_29.bin file...
Reset operation finished
Disconnected.
