06-01-2021, 20:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | J100H Dead Boot Repair 📲 eMMC 🗂️ Medusa Pro 🎊 Octoplus Box 🐙 [Answered] V-Log Welcome to Medusa Pro Software version 2.2.0.1. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7471104 Size : 3648.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211019EB582EE726F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 9EB582EE Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x2 Part setting completed: 0x1 GP partition 1 size : 40 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_31_05_2021_22_54_56.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0.1; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- Selected pit file: D:/Firmware/Samsung/J100H/J100HXXU0AOG4_OXE0AOG4_v4.4.4_Repair_Firmware/J13G.pit Open file "D:/Firmware/Samsung/J100H/J100HXXU0AOG4_OXE0AOG4_v4.4.4_Repair_Firmware/BL_J100HXXU0AOG4_CL698119_QB5670808_REV01_user_low _ship.tar". Open file "D:/Firmware/Samsung/J100H/J100HXXU0AOG4_OXE0AOG4_v4.4.4_Repair_Firmware/AP_J100HXXU0AOG4_CL698119_QB5670808_REV01_user_low _ship.tar". Open file "D:/Firmware/Samsung/J100H/J100HXXU0AOG4_OXE0AOG4_v4.4.4_Repair_Firmware/CP_J100HXXU0AOG4_CL698119_QB5670808_REV01_user_low _ship.tar". Open file "D:/Firmware/Samsung/J100H/J100HXXU0AOG4_OXE0AOG4_v4.4.4_Repair_Firmware/CSC_OXE_J100HOXE0AOG4_CL698119_QB5670808_REV01_use r_low_ship_.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... from 0 to 40 Done. Switched to user area. Writing partition SBOOT... from 2000 to C02 Done. Writing partition SBOOT2... from 3000 to C02 Done. Writing partition wfixnv2... from 4800 to 156 Done. Writing partition WDSP... from 6000 to F02 Done. Writing partition MODEM... from 8000 to 391D Done. Writing partition PARAM... from 14800 to 4D8 Done. Writing partition KERNEL... from 22800 to 2B56 Done. Writing partition RECOVERY... from 2A800 to 357E Done. Writing partition CSC... from 32800 to 9361 Done. Writing partition system... from 96800 to 1CA39C Done. Writing partition HIDDEN... from 29E800 to 3B39 Done. Writing is finished. SW: 2.2.0.1; FW: 1.24. Please select file. Please select file. Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7471104 Size : 3648.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211019EB582EE726F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 9EB582EE Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x2 Part setting completed: 0x1 GP partition 1 size : 40 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_31_05_2021_23_04_35.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00208000) 1040 MB P24: hidden (0029E800, 00014000) 40 MB P25: userdata (002B2800, 0046B800) 2263 MB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/H4G2b_efs_0x15800_0xa000_31_05_2021_23_04_35.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.2.0.1; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : e4000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2129920 Device Manufacturer : samsung Device Platform : sc8830 Build ID : KTU84P Display Build ID : KTU84P.J100HXXU0AOG4 Release ID : 4.4.4 Device Model : SM-J100H Device Name : j13gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : j13gxx-user 4.4.4 KTU84P J100HXXU0AOG4 release-keys --------------------------------------------------------------- Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition modem from D:/J100H EFS Backup For Easy Jtag+/MODEM.bin file... Done. Writing partition modem2 from D:/J100H EFS Backup For Easy Jtag+/MODEM2.bin file... Done. Writing partition efs from D:/J100H EFS Backup For Easy Jtag+/efs.img file... Done. Writing is finished. SW: 2.2.0.1; FW: 1.24. Reconnect the device to see changes. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7471104 Size : 3648.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211019EB582EE726F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 9EB582EE Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x2 Part setting completed: 0x1 GP partition 1 size : 40 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_31_05_2021_23_06_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00208000) 1040 MB P24: hidden (0029E800, 00014000) 40 MB P25: userdata (002B2800, 0046B800) 2263 MB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/H4G2b_efs_0x15800_0xa000_31_05_2021_23_06_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.2.0.1; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : e4000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2129920 Device Manufacturer : samsung Device Platform : sc8830 Build ID : KTU84P Display Build ID : KTU84P.J100HXXU0AOG4 Release ID : 4.4.4 Device Model : SM-J100H Device Name : j13gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : j13gxx-user 4.4.4 KTU84P J100HXXU0AOG4 release-keys --------------------------------------------------------------- |
06-02-2021, 07:36 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Thank you for your feedback. But we have to remind you that we have never indicated anywhere that we provide support for SMART REPORT for SK Hynix eMMC. We support SMART REPORT eMMC for SAMSUNG and SanDisk on Medusa Pro II. Also in the log there is a warning message for your box Samsung eMMC only supports smart report operation! (which you ignored). This screenshot is taken from your video and a message about it appears at 12:18 Last edited by Octopus support; 06-02-2021 at 07:41. |
The Following User Says Thank You to Octopus support For This Useful Post: |
06-02-2021, 07:56 | #3 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | thanks for your deeply investigation about my repair log but it has successfully alive more than 3 pics of hand set at the same time. By the way the method its very easy for SKhynix |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
