10-12-2019, 17:25 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Dominican Republic
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | LG Aristo 3 X220MA Dead wMedusa Pro [Answered] Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Dead after conect to emmc in Medusa Pro now Phone Only conect to Qualcomm HS-USB QDLoader 9008 |
10-12-2019, 21:21 | #2 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Dominican Republic
Member: 2342599 Status: Offline Thanks Meter: 98 | Try connect back using Voltage: 2.6 and usb connected at same time, the other settings let them the same. |
The Following User Says Thank You to starlyn1232 For This Useful Post: |
10-14-2019, 08:13 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Looks like You have some issue with soldering or wires, if your deviec stuck at Qcomm mode. Besides, what was the exact state of your device before You solder wires for eMMC? |
10-15-2019, 03:06 | #4 (permalink) |
Major Poster Join Date: Sep 2017
Member: 2759367 Status: Offline Thanks Meter: 27 | hello greetings from Honduras Honduras, the same thing happened exactly the same x220ma died only when welding cables and only Qualcomm HS-USB port QDLoader 9008 the solution is to change the CLK resistance the value in omnios of CLK is 00.2 omnios and cell phone ready to life I realized that this happened because the soldering iron is too hot and the resistance burns change CLK and you will have your cell phone alive back |
The Following User Says Thank You to franklin1525 For This Useful Post: |
10-15-2019, 23:15 | #6 (permalink) | |
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | Quote:
Thanks i will try change CLK Resistance | |
05-05-2020, 00:33 | #7 (permalink) |
Freak Poster Join Date: Aug 2018
Member: 2856211 Status: Offline Thanks Meter: 29 | you can download the latest version of Qualcomm USB Driver and try |
