Member: 2749393
Thanks Meter: 39 | Quote:
Originally Posted by D. Dragon I couldn't unlock sim so I reflashed it, I tried to repair it using usb and it successfully connected but give me a problem when I flash firmware. | I flashed it using emmc jtag and it finished but still qdloader 9008 Quote:
Welcome to Octoplus Pro JTAG Software version 1.7.7.
Started.
Reader #0: Broadcom Corp Contacted SmartCard 0
Reader #1: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS665
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_LS665_EMMC_QN1SMB.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H8G1e
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : 90014A48384731650507F74BC917A2F3
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H8G1e
Product revision : 0.7
Product serial number : (hex) F74BC917
Manufacturing date : 10/2015
CSD Info
CSD : D02701320F5903FFFFFFFFEF8A4040D3
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G1e_11_11_2019_20_51_07.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
P00: GPT (00000000, 00000400) 512 KB
P01: sbl1 (00000400, 00000400) 512 KB
P02: tz (00000800, 00000400) 512 KB
P03: hyp (00000C00, 00000400) 512 KB
P04: rpm (00001000, 00000400) 512 KB
P05: aboot (00001400, 00001000) 2048 KB
P06: pad (00002400, 00000C00) 1536 KB
P07: sbl1bak (00003000, 00000400) 512 KB
P08: tzbak (00003400, 00000400) 512 KB
P09: hypbak (00003800, 00000400) 512 KB
P10: rpmbak (00003C00, 00000400) 512 KB
P11: abootbak (00004000, 00001000) 2048 KB
P12: misc (00005000, 00008000) 16 MB
P13: persist (0000D000, 00008000) 16 MB
P14: metadata (00015000, 00000400) 512 KB
P15: modemst1 (00015400, 00000C00) 1536 KB
P16: modemst2 (00016000, 00000C00) 1536 KB
P17: laf (00016C00, 0000C000) 24 MB
P18: boot (00022C00, 0000C000) 24 MB
P19: recovery (0002EC00, 0000C000) 24 MB
P20: fsg (0003AC00, 00000C00) 1536 KB
P21: fsc (0003B800, 00000400) 512 KB
P22: ssd (0003BC00, 00000400) 512 KB
P23: DDR (0003C000, 00000400) 512 KB
P24: sec (0003C400, 00000400) 512 KB
P25: encrypt (0003C800, 00000400) 512 KB
P26: eksst (0003CC00, 00000400) 512 KB
P27: rct (0003D000, 00000400) 512 KB
P28: sns (0003D400, 00004000) 8 MB
P29: factory (00041400, 00010000) 32 MB
P30: fota (00051400, 00010000) 32 MB
P31: drm (00061400, 00004000) 8 MB
P32: mpt (00065400, 00010000) 32 MB
P33: modem (00075400, 00020000) 64 MB
P34: persistent (00095400, 00001000) 2048 KB
P35: carrier (00096400, 00014000) 40 MB
P36: system (000AA400, 004ACC00) 2394 MB
P37: cache (00557000, 001A9000) 850 MB
P38: userdata (00700000, 00788000) 3856 MB
P39: grow (00E88000, 00007FDF) 15.98 MB
Opening LS665/LS665ZV4_07.tot file...
Signature OK.
Signature 2 OK.
Open file "LS665/LS665ZV4_07.tot".
Write data verification is enabled.
Writing. Please wait...
Writing partition PrimaryGPT... Done.
Writing partition sbl1... Done.
Writing partition tz... Done.
Writing partition hyp... Done.
Writing partition rpm... Done.
Writing partition aboot... Done.
Writing partition sbl1bak... Done.
Writing partition tzbak... Done.
Writing partition hypbak... Done.
Writing partition rpmbak... Done.
Writing partition abootbak... Done.
Writing partition misc... Done.
Writing partition persist... Done.
Writing partition laf... Done.
Writing partition boot... Done.
Writing partition recovery... Done.
Writing partition sec... Done.
Writing partition rct... Done.
Writing partition factory... Done.
Writing partition modem... Done.
Writing partition system... Done.
Writing partition BackupGPT... Done.
Writing is finished.
Disconnected.
