Member: 135661
Thanks Meter: 92 | PRO first test I9505 emmc write firmware done first let me say thanks for this great tool
jumping from speed 50kb/s in old jtag to 2.5mb/s in emmc write its very nice Quote:
Model Settings:
Interface : eMMC
Brand : Samsung
Model : GT-I9505
SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9505_EMMC_016G94.srf
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 016G94
Page size : 512 B
Block size : 512 B
Block count : 30777344
CID Info
CID : 110100303136473934B05A08C736803D
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 016G94
Product revision : 11.0
Product serial number : (hex) 5A08C736
Manufacturing date : 08/2013
CSD Info
CSD : D00E00320F5903FFFFFFFFFF92400025
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 1 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 512 Kbytes
Partition config : 00000000
Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7700480 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 225864
Number of sectors : 5652480
Device Manufacturer : samsung
Device Platform : msm8960
Build ID : LRX22C
Display Build ID : LRX22C.I9505XXSPQA1
Release ID : 5.0.1
Device Model : GT-I9505
Device Name : jfltexx
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Architecture ABI List : armeabi-v7a,armeabi
Build Description : jfltexx-user 5.0.1 LRX22C I9505XXSPQA1 release-keys
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/016G94_10_06_2017_09_52_39.bin.
Connect successful.
SW: 1.3.8; FW: 1.18.
P00: GPT (00000000, 00002000)
P01: apnhlos (00002000, 000063C8)
P02: mdm (000083C8, 00019C38)
P03: sbl1 (00022000, 00000100)
P04: sbl2 (00022100, 00000200)
P05: sbl3 (00022300, 00000400)
P06: aboot (00022700, 00001000)
P07: rpm (00023700, 00000400)
P08: tz (00023B00, 00000400)
P09: pad (00023F00, 00008400)
P10: efs (0002C300, 00006D00)
P11: modemst1 (00033000, 00001800)
P12: modemst2 (00034800, 00001800)
P13: m9kefs1 (00036000, 00000618)
P14: m9kefs2 (00036618, 00000618)
P15: m9kefs3 (00036C30, 00000618)
P16: system (00037248, 00564000)
P17: persist (0059B248, 00004000)
P18: cache (0059F248, 0040B000)
P19: param (009AA248, 00003000)
P20: boot (009AD248, 00005000)
P21: recovery (009B2248, 00005000)
P22: fota (009B7248, 00005000)
P23: backup (009BC248, 00003000)
P24: fsg (009BF248, 00001800)
P25: ssd (009C0A48, 00000010)
P26: persdata (009C0A58, 00004800)
P27: hidden (009C5258, 000FA000)
P28: carrier (00ABF258, 0000A000)
P29: userdata (00AC9258, 0128E000)
Selected pit file: E:/Flash02/Samsung/SAMSUNG-Ixx/I9505/CSB_signed_Fusion3_EUR_0325_V2.pit
Open file "E:/Flash02/Samsung/SAMSUNG-Ixx/I9505/I9505XXSPQA1_I9505PHNPQB2_PHN/I9505XXSPQA1_I9505PHNPQB2_I9505XXSPQA1_HOME.tar.md 5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Writing partition APNHLOS... Done.
Writing partition MDM... Done.
Writing partition SBL1... Done.
Writing partition SBL2... Done.
Writing partition SBL3... Done.
Writing partition ABOOT... Done.
Writing partition RPM... Done.
Writing partition TZ... Done.
Writing partition SYSTEM... Done.
Writing partition CACHE... Done.
Writing partition BOOT... Done.
Writing partition RECOVERY... Done.
Writing partition HIDDEN... Done.
Writing is finished.
