11-08-2019, 18:47 | #1 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | SM-J410F eMMC is Read Only Problem !! How to Fix it ?? Need Solution [Answered] Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: Mobile Broadband SIM Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_08_11_2019_19_18_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/J410F/EXT_CSD_08_11_2019_19_19_18.bin. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_08_11_2019_19_20_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_08_11_2019_19_20_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_08_11_2019_19_21_48.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_08_11_2019_19_23_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB Selected pit file: D:/Firmware/Samsung/J410F/J4CORELTE_MEA_OPEN.pit Open file "D:/Firmware/Samsung/J410F/BL_J410FXXU1ARJD_CL14467434_QB20283525_REV00_user_ low_ship_MULTI_CERT.tar". Open file "D:/Firmware/Samsung/J410F/AP_J410FXXU1ARJD_CL14467434_QB20283525_REV00_user_ low_ship_MULTI_CERT_meta.tar". Open file "D:/Firmware/Samsung/J410F/CP_J410FXXU1ARJF_REV00_CL939150__QB_11053328.tar". Open file "D:/Firmware/Samsung/J410F/CSC_OMC_OJM_J410FOJM1ARJD_CL14467434_QB20283525_RE V00_user_low_ship_MULTI_CERT.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT... ERROR[012]: Write error. At sector 30777311. Disconnected. |
11-09-2019, 00:04 | #2 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Sorry Octoplus Pro cant remove PERM_WRITE_PROTECT or cant Factory Format will erase all eMMC data! Smart report info: Hash code: 00000000000000000000000000000000000000000000000000 00000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.7.7; FW: 1.24. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420015C797065617 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 15C79706 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E406069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXS1ASD4 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXS1ASD4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/FE62MB_09_11_2019_00_54_40.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB |
