Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 06-02-2017, 08:31   #1 (permalink)
Member: 976682
Thanks Meter: 5
What is CID and how to chnge it?
hi to anyone
i have one questions
whate is cid change ?
when we need to change cid ?
and in all cpu we need it ?
tnx all
The Following 2 Users Say Thank You to manan-hanan For This Useful Post:
Old 06-02-2017, 13:32   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello.
As You may know, eMMC chip has different registers - CID Register, CSD Register, Extended CSD Register. Most of bits in these registers are Read Only, and only some of them can be changed. The Card Identification (CID) register is 128 bits wide. It contains the Device identification information (Manufacturer ID, Product Name, Product Revision, Product Serial Number, Manufacturing Date and some others) used during the Device identification phase (eMMC protocol).
Samsung eMMC chips let to change of CID data. eMMC chips of other vendors don't allow (or method is unknown) to change CID.
You may need to change CID if You want to change or repair some data in it, for example, if device (eMMC) has damaged Product Name and it should be corrected. Or often when You want to change eMMC chip in device to another similar (Samsung) eMMC, it can be necessary to change CID of new Samsung eMMC to similar, that was in old eMMC.
This doesn't depends on device CPU, this depends on the problem.
This is in a few words in general. More info You can read from official JEDEC eMMC specification:
https://www.jedec.org/standards-docu...ufs-emmc/e-mmc,
http://www.issi.com/WW/pdf/IS21_22ES...G_32G_64GB.pdf,
http://theroot.ninja/disclosures/.
The Following 17 Users Say Thank You to Medusa Box For This Useful Post:
Page generated in 0.11439 seconds with 8 queries
