01-12-2017, 12:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | Cant remove frp X190 [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.4.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM70 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Port busy Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM70 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Port busy Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM117 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader... Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM70 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Port busy Performed by 2.4.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM70 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Port busy Performed by 2.4.5 Software version. Last edited by Octopus box; 05-24-2017 at 15:15. |
01-12-2017, 13:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,415 | Hello. Please, install the latest Software version make sure that You install all drivers for correct work of your device, after repeat "Reset FRP" operation again. |
01-12-2017, 15:11 | #3 (permalink) |
Member: 2800 Status: Offline Thanks Meter: 47 | Downloaded latest soft,but same problem. Which drivers i need? Welcome to Octoplus/Octopus Box LG Software version 2.5.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM70 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Port busy Performed by 2.5.6 Software version. |
01-12-2017, 16:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,415 | Please, try to re-install MTK drivers manually, most likely some drivers has conflict in your system. If problem still remain try on another clean PC with installed drivers and Software. Phone must be connected directly to PC, don't use USB HUBS. |
05-23-2017, 12:25 | #5 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | hi i have the same problem Checking data...OK Platform: LG MTK Selected port: COM303 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Found model at port COM30 Port busy Performed by 2.6.6 Software version. |
05-23-2017, 12:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,415 | @unlockmachine44 Hello. Please, try to re-install MTK drivers manually, most likely some drivers has conflict in your system. If problem still remain try on another clean PC with installed drivers and Software. Phone must be connected directly to PC, don't use USB HUBS. |
05-24-2017, 14:50 | #7 (permalink) | |
Member: 1350724 Status: Offline Thanks Meter: 188 | Quote:
Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 0 Selected model: X190 Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6592 CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Found model at port COM6 Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 35xxxxxxxxxxxxx IMEI B: 35459xxxxxxxxxxxxxxxx Bluetooth address: 80:5A:04:58:7B:52 Wi-Fi MAC address: 80:5A:048:F7:41 EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 15032 Mb -------------------------------------------------------------------------------- Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! Performed by 2.6.6 Software version. | |
