04-11-2017, 12:10 | #1 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | F500L Flashing Issues I m having issues with F500L, during flash having this particular error Quote:
LGF500LAT-00-V21a-LGU-KR-DEC-16-2016+0 Phone was running with PIN Lock, i tried reset screen lock options of Octopus , but nothing Regards | |
04-11-2017, 13:00 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Quote:
What is the exact state of your phone now? | |
04-11-2017, 13:11 | #3 (permalink) | ||
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
04-11-2017, 14:32 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Please, upload to some file share this firmware file "LGF500LAT-00-V21a-LGU-KR-DEC-16-2016+0" then post here link, we will check it. |
04-12-2017, 06:31 | #5 (permalink) | |
https://drive.google.com/file/d/0B89...02N2VWSFk/view | |
04-12-2017, 08:20 | #6 (permalink) | |
Member: 319447 Status: Offline Thanks Meter: 4,949 | After 2 days of try, downloaded file from your support area. result as below. Quote:
04-12-2017, 12:27 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | The firmware "LGF500LAT-00-V21a-LG-KR-DEC-16-2016+0" file isn't the original firmware file , it was read out from the phone. Try to find stock V21 firmware file and then reflash your device. Also You can try to download and install test Software version form the Support Area (LG/TEST SOFTWARE/), then repeat Write Firmware operation with "LGF500LAT-00-V21a-LG-KR-DEC-16-2016+0" file but only at your own risk. |
04-13-2017, 08:07 | #8 (permalink) | |
Did you also uploaded same read out firmware i used to flash ? Regards | |
04-17-2017, 07:50 | #12 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | The phone is Refurbish Right ? you need a modify System.img which edit for this Model only i can give you a link where you get such file Here This File will solved the problem |
04-18-2017, 05:36 | #13 (permalink) | |
also one more point is, flashing continues in Flasher but stuck at "0" in Phone. anything else anyone ? | |
