01-05-2017, 23:31 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | flash h811 with file from support LGH811AT-00-V20o-TMO-US-JUN-13-2016-ARB03+0-TOT Welcome to Octoplus/Octopus Box LG Software version 2.5.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM425 Selected model: H811 Reading info... Model ID: LG-H811 IMEI: 359105-06-05 Android version: 6.0 Battery level: 64% SW Version: H81120q Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V20q-310-260-NOV-23-2016-ARB03+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT02S150521006741 IMEI: 359105-06-0 Target operator: TMO Hardware: rev_10 Performed by 2.5.2 Software version. - |
01-06-2017, 02:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | No, it is not safe. Your phone has V20q and you want to flash V20o that is an older version firmware ( in the alphabet "o" comes before "q" so : q =newer o = older Flashing an older firmware like you want to do will brick your phone You can only flash same version or newer. |
The Following User Says Thank You to spagman For This Useful Post: |
01-20-2017, 08:24 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Quote:
Try to put the phone into Download Mode manually. If the phone doesn't go into DM, You can try to repair it using tool, which supports repairing this device via eMMC or USB. | |
01-21-2017, 06:08 | #7 (permalink) |
Insane Poster Join Date: Aug 2016 Location: islamabad
Member: 2605823 Status: Offline Thanks Meter: 10 | plz help my phone stuck on logo after write firmware failed; Checking data...OK Platform: LG Qualcomm Selected port: COM25 Selected model: H811 Reading info... Model ID: LG-H811 IMEI: 359105-06-432252-6 Android version: 6.0 Battery level: 61% SW Version: H81120q Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V20q-310-260-NOV-23-2016-ARB03+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT01S150819001545 IMEI: 359105-06-432252-6 Target operator: TMO Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGH811AT-00-V20o-TMO-US-JUN-13-2016-ARB03+0- TOT.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...Failed! Error code: ZXLCALSZXD Performed by 2.5.6 Software version. |
01-21-2017, 09:39 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | What was initial state of the phone? Why did You decide to reflash it? According to the Software log, You have downgraded phone's firmware version from V20q to V20o. Downgrading can damage your device. Can You put your device into Emergency (Download) Mode manually? |
01-27-2017, 08:20 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | @ mmdscorp Hello. What is the state of your phone now? Can You put your device into Emergency (Download) Mode manually? What device appear in PC Device Manager when You connect the phone to PC? Last edited by Octopus box; 01-27-2017 at 09:17. |
04-26-2017, 08:29 | #11 (permalink) | |
Freak Poster Join Date: Nov 2009 Location: Honduras-Comayagua Age: 35
Member: 1163489 Status: Offline Thanks Meter: 23 | Quote:
1 repair by emmc box 2 sd card dump emmc (64gb and working phone needle) 3 qpst firehorse method google search bro.. good look and now you know to be very carefull on lg phone´s flash procedure, never downgrade inclusive marsmallow 6.0 can brick same version. 20i 20o 20p 20q in order for the date build and alphanumeric order a,b,c,d,e,f,g,h etc.. not b,a,z... im sorry for you frend, you have a dead phone now. | |
