12-08-2021, 05:51 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | FRP LMX410MK successfully Work ID: 0000000001EF6710 Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: LMX410MK Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X410MK IMEI: Android version: 8.1.0 Battery level: 70% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX410MKAT-02-V20j-310-160-JUL-26-2019-ARB00 +0 Android version: 8.1.0 LAF Version: 1.1 Product ID: IMEI: Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 300 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "LMX410MK__07-12-2021_ 23-44-39.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.1.5.03 Software version. |
The Following 2 Users Say Thank You to windowshu For This Useful Post: |
