03-28-2023, 22:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | FRP removal fail LM-Q610TA [Solved] I tried removing FRP from an LG-Q610TA. The process started but ended with message saying backup saved. I closed the program an re-tried now it is asking for 100 credits again to perform request. I need this resolve soon please. Code: Welcome to Octoplus/Octopus Box LG Software version 3.2.1.05 Card S/N : 0000010D7E -------------------------------------------------------------------------------- Connecting to server 0...OK Username: 5kpNQHQVZ8 Authorizing...OK Checking balance...OK Your balance: 60 credits. -------------------------------------------------------------------------------- Work ID: 0000000001E52C8A Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: Q610TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q610TA IMEI: 357568-09-134331-4 Android version: 8.1.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ610TAAT-01-V10r-310-260-JUN-03-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS93S190217000103 IMEI: 357568-09-134331-4 Target operator: TMO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: 5kpNQHQVZ8 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 60 credits. To perform "Reset FRP" operation you need to have 100 credits. Performed by 3.2.1.05 Software version. |
03-29-2023, 06:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We added you one more attempt. Please, perform operation once again follow software manual and post here result. |
03-29-2023, 15:26 | #4 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | Thank You support for quick response. All went well. See below Code: Welcome to Octoplus/Octopus Box LG Software version 3.2.1.05 Card S/N : 0000010D7E -------------------------------------------------------------------------------- Connecting to server 0...OK Username: 5kpNQHQVz8 Authorizing...OK Checking balance...OK Your balance: 160 credits. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: 5kpNQHQVz8 Authorizing...OK Checking balance...OK Your balance: 160 credits. -------------------------------------------------------------------------------- Work ID: 0000000001E58933 Checking data...OK Platform: LG Qualcomm Selected port: COM29 Selected model: Q610TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 3.2.1.05 Software version. -------------------------------------------------------------------------------- Work ID: 000000000195223D Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: Q610TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q610TA IMEI: 357568-09-134331-4 Android version: 8.1.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ610TAAT-01-V10r-310-260-JUN-03-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS93S190217000103 IMEI: 357568-09-134331-4 Target operator: TMO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: 5kpNQHQVz8 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 160 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "Q610TA_357568091343314_29-03-2023_09-18-49.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.2.1.05 Software version. |
The Following User Says Thank You to beerfoote1 For This Useful Post: |
