05-17-2021, 15:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | h790 frp lock not removed [Answered] Card S/N : 0000??????? -------------------------------------------------------------------------------- Work ID: 0000000001023602 Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H790 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Could not detect mode! Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Work ID: 000000000102364C Checking data...OK Platform: LG Qualcomm Selected port: COM87 Selected model: H790 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...?????????????????? Android version: Battery level: 71% Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LGH790AT-00-V22a-NXS-XXX-MAR-07-2017-32G- N2G47F-USER+0 Android version: 6.0 LAF Version: 1.2 Product ID: E0000011801269208 IMEI: 3??????????????? Target operator: GOOGLE Hardware: After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare. Perform Reset FRP operation at your own risk. Continue? Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 3.1.1.03 Software version. software showed frp removed but still set is frp locked i tried hard reset via recovery and then try again but still same issue. |
