11-27-2015, 03:24 | #1 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2492642 Status: Offline Thanks Meter: 1 | LG G4 H812 unlock [Solved] I am using Octoplus box LG 2.1.3 to unlock the LG G4 H812 with bad esn. But I was stuck at the screen. Trying to enable to Diagnostics ports.... Initalizing ADB.....OK ADB Server was found. Trying to kill..... Waiting for phone......Failed! Nothing is happening on the phone after this message. Normally, the phone should have pop-up message. I hope someone can help. Thanks Last edited by Octopus box; 12-01-2015 at 11:28. |
11-27-2015, 11:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Please install the following drivers and restart PC. http://octoplusbox.com/files/drivers..._Ver_4.0.3.exe Close all third party Software (modem dashboards, Android managers, etc.) and disconnect all other devices from PC (modems, phones, boxes, etc.) after PC restart. Try to perform "Unlock" operation again. Post here result and full Software log of the operation. Note: To connect the phone in Normal Mode, do one of the following: 1. Enable "USB Debugging" mode; 2. Type 277634#*#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
11-30-2015, 12:33 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Please post here, or send us in PM full Software log of "Unlock" operation. |
12-01-2015, 03:30 | #7 (permalink) |
Member: 2492642 Status: Offline Thanks Meter: 1 | I finally figured it out, caused from the driver. Lg G4 H812 is blacklisted unlocked successfully. thanks. |
The Following User Says Thank You to bmobmobmobmobmo For This Useful Post: |
