02-06-2022, 15:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | LG H791AT Write Firmware Question [Answered] Card S/N : 000001B723 Cannot call Start on a running or suspended thread -------------------------------------------------------------------------------- Work ID: 000000000235D7A5 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000235D7D1 Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: H791 Reading info... IMEI: 353627-07-501323-8 Android version: Battery level: 24% Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G- MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: HD54S151030000297 IMEI: 353627-07-501323-8 Target operator: GOOGLE Hardware: -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-32G- MDA89E-US-TOT.oct"...OK Selecting firmware partitions...OK Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Writing recovery...OK Writing system...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000235DB77 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000235DE54 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000235DE5E Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: H791 Reading info... IMEI: 353627-07-501323-8 Android version: Battery level: 31% Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G- MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: HD54S151030000297 IMEI: 353627-07-501323-8 Target operator: GOOGLE Hardware: -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-32G- MDA89E-US-TOT.oct"...OK Selecting firmware partitions...OK Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sec...OK Writing persist...OK Writing laf...OK Writing recovery...OK Writing system...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000235E0EC Checking data...OK Platform: LG Qualcomm Selected port: COM2 Selected model: H791 Reading info...Failed! Could not detect mode! Performed by 3.1.7 Software version. |
02-07-2022, 09:00 | #5 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Quote:
What firmware was on the device before? It was official firmware or custom? Last edited by Octopus support; 02-07-2022 at 14:39. | |
02-07-2022, 14:45 | #7 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | If your device stuck in Qualcomm HS-USB QDLoader 9008 that you can restore your device using Medusa Pro II. Unfortunately, we cannot offer you an alternative solution to your issue. Last edited by Octopus support; 02-09-2022 at 09:11. |
02-09-2022, 08:47 | #8 (permalink) | |
Member: 1215266 Status: Offline Thanks Meter: 129 | Quote:
02-14-2022, 08:59 | #11 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. If you have loader for your device, so you will only need to work with the testpoint. But if you do not have a loader, then you will need to work directly with flash memory. |
