12-30-2021, 00:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | LG K22 Plus FRP Done Checking data...OK Platform: LG Qualcomm Selected port: COM130 Selected model: K200HAW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-K200HAW IMEI: 35XX73-25-14XX9X-X Android version: 10 Battery level: 24% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: Android version: 10 LAF Version: 1.1 Product ID: 0BAKCU34RQ7602Q4G IMEI: 35XX73-25-14XX9X-X Target operator: Hardware: Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: the.phone.tech.doc Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: XXX credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "K200HAW_35XX732514XX9XX_29-12-2021_16- 03-55.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.1.6 Software version. |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
