02-01-2022, 02:18 | #1 (permalink) |
Junior Member Join Date: Jul 2017 Location: México
Member: 2736322 Status: Offline Thanks Meter: 9 | LG K300TM Unlock Question [Solved] Selected USB connection type Work ID: 00000000022FBF72 Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: K300TM Please, select Unlock Method! Selected Unlock via ADB Initializing ADB...OK Waiting for phone...OK Model ID: LM K300TM Phone firmware version: LMK300AT 00 V10l LAO COM OCT 01 2021 ARB00+0 Baseband version: MOLY LR12A R3 TC01 DH SP V1 P52, 2021 10 01 11:29 Android version: 10 Target operator: TMO Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: oct_sn54WdS Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending loader... Reading info... IMEI: 353833340719142 Reading SIMLOCK... Obtained wrong response! Failed! Performed by 3.1.6 Software version. |
02-01-2022, 08:41 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. We added your one more attempt. Please, download and install latest test Software v. 3.1.6.05 from Support Area (Path:/SOFTWARE/Octoplus LG/TEST SOFTWARE/install_octoplus_octopus_LG_3.1.6.05.exe) Then repeat operation once again and post here results. We will check it. Note: Read attentively Software instructions. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
02-01-2022, 22:48 | #3 (permalink) |
Member: 2736322 Status: Offline Thanks Meter: 9 | Hi, I tried with the wipe security method and it worked, thanks Welcome to Octoplus Octopus Box LG Software version 3 1 6 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000022FCA9C Checking data OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K300TM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM6 Mode: Emergency Initializing flash...OK Model ID: LM K300TM Platform: mt6765 Code name: mdh5lm Android version: 10 SW version: LMK300TMAT 01 V10l 310 260 OCT 01 2021 ARB00 +0 LAF Version: 1.1 Product ID: VP01S210417004103 IMEI: 353833340719142 Target operator: LAO Hardware: rev 10 Battery level: 100% Reading partitions...OK LAF Error: 80000119 Checking security...OK -------------------------------------------------------------------------------- IMEI: 353833340719142 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: oct_sn54WdS Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM9 Detecting Chip Version... Platform: MT6765: 0766 0000 HW version: 8A00 CA00 0000 0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM11 Detecting Chip Version... Platform: MT6765: 0766 0000 HW version: 8A00 CA00 0000 0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766 0000 HW version: 8A00 CA00 0000 0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC flash chip: 15010051 5836334D 4203D80E 0765C7C7 eMMC flash chip: Unknown: QX63MB Internal RAM size: 224 Kb External RAM size: 2048 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "K300TM 353833340719142 31 01 2022 21 03 47 SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... Phone successfully unlocked! Performed by 3.1.6 Software version. |
The Following User Says Thank You to juancar273 For This Useful Post: |
