12-27-2021, 23:02 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2122242 Status: Offline Thanks Meter: 63 | LG-K500MM v20g Unlock question [Answered] -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000208ACD6 Checking data...OK Platform: LG MTK Selected port: COM14 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via ADB Initializing ADB...OK Waiting for phone...OK Model ID: LM-K500MM Phone firmware version: LMK500AT-00-V20g-LAO-COM-NOV-19-2021- ARB00+0 Baseband version: MOLY.LR12A.R3.TC01.DH.SP.V1.P55 Android version: 11 Target operator: MPCS Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: sergiosierra Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: XX1 credits. To perform "Unlock" operation you need to have 100 credits. Sending loader... Reading info... IMEI: XXXXXXXXXX45568 Reading SIMLOCK... Obtained wrong response! Failed! Performed by 3.1.6 Software version. Security patch: 1/December/2021 Thansk in advance!!! Last edited by sergiosierra; 12-27-2021 at 23:07. |
12-27-2021, 23:26 | #2 (permalink) |
Member: 2122242 Status: Offline Thanks Meter: 63 | Via Wipe Security: Welcome to Octoplus/Octopus Box LG Software version 3.1.6.01 Card S/N : 0100003F72 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000208B196 Checking data...OK Platform: LG MTK Selected port: COM14 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM37 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Code name: mdh30xlm Android version: 11 SW version: LMK500MMAT-02-V20g-310-160-NOV-19-2021- ARB00+0 LAF Version: 1.1 Product ID: WI07S210429004229 IMEI: XXXXXX-XX-XX4556-8 Target operator: LAO Hardware: rev_10 Battery level: 69% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: XXXXXX-XX-XX4556-8 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: sergiosierra Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: XX1 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM37 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM26 |
12-28-2021, 10:15 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please connect the phone into another USB port from your motherboard and repeat the Unlock operation once again, post here results. Also, use only stock original USB cable. |
12-28-2021, 13:40 | #4 (permalink) | |
Member: 2122242 Status: Offline Thanks Meter: 63 | Quote:
Same problem in another PC Welcome to Octoplus/Octopus Box LG Software version 3.1.6.01 -------------------------------------------------------------------------------- Connecting to server 0...OK Username: sergiosierra Authorizing...OK Checking balance...OK Your balance: XX1 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000002092755 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via ADB Initializing ADB...OK Waiting for phone...OK Model ID: LM-K500MM Phone firmware version: LMK500AT-00-V20g-LAO-COM-NOV-19- 2021-ARB00+0 Baseband version: MOLY.LR12A.R3.TC01.DH.SP.V1.P55 Android version: 11 Target operator: MPCS Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: sergiosierra Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: XX1 credits. To perform "Unlock" operation you need to have 100 credits. Sending loader... Reading info... IMEI: XXXXXXXXXX45568 Reading SIMLOCK... Obtained wrong response! Failed! Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000002092AF2 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Mode: Normal Switching to Download mode... Phone found at port COM10 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Code name: mdh30xlm Android version: 11 SW version: LMK500MMAT-02-V20g-310-160-NOV-19-2021- ARB00+0 LAF Version: 1.1 Product ID: WI07S210429004229 IMEI: XXXXXXXXXX45568 Target operator: LAO Hardware: rev_10 Battery level: 65% Reading partitions... Performed by 3.1.6.01 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000002092B43 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K500MM Please, select Unlock Method! Selected Unlock via wipe security Connecting to phone... Phone found at port COM10 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Code name: mdh30xlm Android version: 11 SW version: LMK500MMAT-02-V20g-310-160-NOV-19-2021- ARB00+0 LAF Version: 1.1 Product ID: WI07S210429004229 IMEI: XXXXXXXXXX45568 Target operator: LAO Hardware: rev_10 Battery level: 65% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: XXXXXXXXXX45568 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: sergiosierra Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: XX1 credits. To perform "Unlock" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM10 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM9 | |
12-28-2021, 16:17 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, delete LG_DA_V0.orf and all preloaders from: Program files(x86)/octoplus/octoplus_lg/data then repeat Unlock operation again and post here result. |
