12-07-2021, 14:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | Lg k510zmw imei repair [Solved] Card S/N : -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM5 Selected baudrate: 921600 Selected model: K510ZMW Connecting to phone... Phone found at port COM6 Mode: Emergency Initializing flash...OK Model ID: LM-K510ZMW Platform: mt6765 Code name: mdh35lm Android version: 10 SW version: LMK510ZMWAT-00-V20b-ZAF-XX-MAR-10-2021+0 LAF Version: 1.1 Product ID: WI15S200710013044 IMEI: 353269-11-076237-8 Target operator: LAO Hardware: rev_10 Battery level: 54% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: XXXXXXXXXXXXX IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.5 Software version. Whats problem and how can i solve ??? |
12-07-2021, 16:39 | #3 (permalink) |
Member: 158181 Status: Offline Thanks Meter: 113 | hello sir problem here Connecting to server 0...OK Username: Shamimobile Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001EEBD70 Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 0 Selected model: K510ZMW Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM6 Mode: Emergency Initializing flash...OK Model ID: LM-K510ZMW Platform: mt6765 Code name: mdh35lm Android version: 10 SW version: LMK510ZMWAT-00-V20b-ZAF-XX-MAR-10-2021+0 LAF Version: 1.1 Product ID: WI15S200710013044 IMEI: 353269-11-076237-8 Target operator: LAO Hardware: rev_10 Battery level: 54% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353269-11-076237-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Shamimobile Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM6 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM12 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .90014A68.43386150.3E0300CD.12364777 eMMC flash chip: Unknown: hC8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "K510ZMW_353269110762378_07-12-2021_20- 05-12.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.5.03 Software version. system was stuk and cannot connect phone with pc meanwhile software it self stop and i lost my credits i try again and now getting error that donat have cradits my 100 credits gone plz fix |
12-07-2021, 17:03 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We added you one more attempt, please try to repeat Repair Imei operation again follow software instruction Quote:
12-08-2021, 09:14 | #5 (permalink) |
Member: 158181 Status: Offline Thanks Meter: 113 | thx for reply sir but one thing i want to tell that i m faceing modem drivers issue on my pc and now i just change my pc modem driver issue solved sir i want to know that can i use my box on my secend pc where drivers is ok |
12-08-2021, 10:46 | #6 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Quote:
Please, send us successfully log of operation. | |
12-08-2021, 14:29 | #7 (permalink) | |
Member: 158181 Status: Offline Thanks Meter: 113 | Imei Not Changed Quote:
Welcome to Octoplus/Octopus Box LG Software version 3.1.5.03 Card S/N : 0100004B69 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001F003CE Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 0 Selected model: K510ZMW Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM15 Mode: Emergency Initializing flash...OK Model ID: LM-K510ZMW Platform: mt6765 Code name: mdh35lm Android version: 10 SW version: LMK510ZMWAT-00-V20b-ZAF-XX-MAR-10-2021+0 LAF Version: 1.1 Product ID: WI15S200710013044 IMEI: 353269-11-076237-8 Target operator: LAO Hardware: rev_10 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353269-11-076237-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Shamimobile Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM15 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM12 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .90014A68.43386150.3E0300CD.12364777 eMMC flash chip: Unknown: hC8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "K510ZMW_353269110762378_08-12-2021_18- 18-37.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: 353548-11-111556-5 New IMEI B: 353548-11-137056-6 Finalizing... Performed by 3.1.5.03 Software version. whats problem?? | |
12-08-2021, 14:46 | #8 (permalink) | |
We added your one more attempt. Repeat operation once again and please, follow attentive Software instructions. Post here results. | |
The Following User Says Thank You to Octopus support For This Useful Post: |
12-08-2021, 15:17 | #9 (permalink) |
Member: 158181 Status: Offline Thanks Meter: 113 | Really Thx For Great Feed Back From Team Finaly JOb Done Here Is Log Selected USB connection type Work ID: 0000000001F011D3 Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 0 Selected model: K510ZMW Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM15 Mode: Emergency Initializing flash...OK Model ID: LM-K510ZMW Platform: mt6765 Code name: mdh35lm Android version: 10 SW version: LMK510ZMWAT-00-V20b-ZAF-XX-MAR-10-2021+0 LAF Version: 1.1 Product ID: WI15S200710013044 IMEI: 353269-11-076237-8 Target operator: LAO Hardware: rev_10 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353269-11-076237-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: Shamimobile Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM15 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM12 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .90014A68.43386150.3E0300CD.12364777 eMMC flash chip: Unknown: hC8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "K510ZMW_353269110762378_08-12-2021_18- 52-50.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: New IMEI B: Finalizing... Rebooting phone... IMEI successfully fixed! Performed by 3.1.5.03 Software version. |
The Following 2 Users Say Thank You to shami For This Useful Post: |
