01-17-2022, 11:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | LG-K520K Blinking Fix & FRP Reset Done Checking data...OK Platform: LG Qualcomm Selected port: COM33 Selected model: K520K Reading info... Model ID: LG-K520K IMEI: Android version: 6.0.1 Battery level: 67% Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520KAT-00-V10e-ZAF-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT68S160815004853 IMEI: Target operator: GLOBAL Hardware: rev_10 Opening "K52010c_00_1014_Vodafone_6.0.1.kdz"...OK Firmware version: K52010v Firmware model: LG-K520 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Sending signature...OK Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/56 PrimaryGPT_0.bin...OK Writing 2/56 sbl1_1024.bin...OK Writing 3/56 tz_2048.bin...OK Writing 4/56 hyp_3072.bin...OK Writing 5/56 rpm_4096.bin...OK Writing 6/56 aboot_5120.bin...OK Writing 7/56 sbl1bak_12288.bin...OK Writing 8/56 tzbak_13312.bin...OK Writing 9/56 hypbak_14336.bin...OK Writing 10/56 rpmbak_15360.bin...OK Writing 11/56 abootbak_16384.bin...OK Writing 12/56 persist_53248.bin...OK Writing 13/56 laf_93184.bin...OK Writing 14/56 boot_142336.bin...OK Writing 15/56 recovery_191488.bin...OK Writing 16/56 recoverybak_240640.bin...OK Writing 17/56 sec_295936.bin...OK Writing 18/56 rct_299008.bin...Skipped! Writing 19/56 factory_316416.bin...OK Writing 20/56 modem_513024.bin...OK Writing 21/56 cust_688128.bin...OK Writing 22/56 system_892928.bin...OK Writing 23/56 system_1156616.bin...OK Writing 24/56 system_1160632.bin...OK Writing 25/56 system_1421232.bin...OK Writing 26/56 system_1680904.bin...OK Writing 27/56 system_1684920.bin...OK Writing 28/56 system_1945520.bin...OK Writing 29/56 system_2205192.bin...OK Writing 30/56 system_2209208.bin...OK Writing 31/56 system_2469808.bin...OK Writing 32/56 system_2729480.bin...OK Writing 33/56 system_2733496.bin...OK Writing 34/56 system_2994096.bin...OK Writing 35/56 system_3253768.bin...OK Writing 36/56 system_3257784.bin...OK Writing 37/56 system_3518384.bin...OK Writing 38/56 system_3780528.bin...OK Writing 39/56 system_4042672.bin...OK Writing 40/56 system_4304816.bin...OK Writing 41/56 system_4566960.bin...OK Writing 42/56 system_4829104.bin...OK Writing 43/56 system_5091248.bin...OK Writing 44/56 system_5353392.bin...OK Writing 45/56 system_5615536.bin...OK Writing 46/56 system_5877680.bin...OK Writing 47/56 system_6139824.bin...OK Writing 48/56 system_6401968.bin...OK Writing 49/56 system_6660096.bin...OK Writing 50/56 system_6922240.bin...OK Writing 51/56 system_6925304.bin...OK Writing 52/56 OP_7651328.bin...OK Writing 53/56 OP_7913472.bin...OK Writing 54/56 OP_8175616.bin...OK Writing 55/56 OP_8178832.bin...OK Writing 56/56 BackupGPT_30534656.bin...Skipped! Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 3.1.4 Software version. -------------------------------------------------------------------------------- Work ID: 00000000021F5356 Checking data...OK Platform: LG Qualcomm Selected port: COM33 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K520K IMEI: Android version: 6.0.1 Battery level: 69% Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520KAT-00-V10v-GLOBAL-COM-OCT-14-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT68S160815004853 IMEI: Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 3.1.4 Software version. |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
