12-23-2021, 19:25 | #1 (permalink) |
Junior Member Join Date: Feb 2017 Location: South Africa
Member: 2682769 Status: Offline Thanks Meter: 1 | LG L22 Unlock question [Answered] I have been network unlocking LG L22 phones for a while now but ever since the Box was updated to 3.0.1 until the latest version I receive Writing security area...Failed!. . . I have tried flashing firmwares and changing PCs no luck and I have more than one unit to unlock so this is an Octoplus software problem. Log Below. 12/20/2021 8:30:53 AM > -------------------------------------------------------------------------------- 12/20/2021 8:30:54 AM > Transport: Connected 12/20/2021 8:30:55 AM > Authorized. 12/20/2021 8:30:56 AM > Work ID: 0000000001FECC0A 12/20/2021 8:30:56 AM > Checking data...12/20/2021 8:30:57 AM > OK 12/20/2021 8:30:57 AM > Platform: LG Qualcomm 12/20/2021 8:30:57 AM > Selected port: COM9 12/20/2021 8:30:57 AM > Selected model: L22 12/20/2021 8:30:57 AM > Reading info... 12/20/2021 8:30:59 AM > Model ID: LGL22 12/20/2021 8:30:59 AM > IMEI: 357XXXXXXXXXXX 12/20/2021 8:30:59 AM > Android version: 4.4.2 12/20/2021 8:30:59 AM > Battery level: 75% 12/20/2021 8:31:33 AM > Trying to enable Diagnostics ports...12/20/2021 8:31:33 AM > Failed! 12/20/2021 8:31:33 AM > Trying to enable Diagnostics ports... 12/20/2021 8:31:33 AM > Initializing ADB...12/20/2021 8:31:35 AM > OK 12/20/2021 8:31:35 AM > Waiting for phone...12/20/2021 8:31:39 AM > OK 12/20/2021 8:31:42 AM > Diagnostics ports are enbled! 12/20/2021 8:31:42 AM > Switching to Serial Port... 12/20/2021 8:31:58 AM > Found model LGL22 at port COM9 12/20/2021 8:31:58 AM > Unlocking... 12/20/2021 8:31:59 AM > Skip Read/Write QCN 12/20/2021 8:31:59 AM > Do you want to create security backup? 12/20/2021 8:32:03 AM > Switching to Download mode...12/20/2021 8:32:29 AM > OK 12/20/2021 8:32:29 AM > Initializing flash...12/20/2021 8:32:30 AM > OK 12/20/2021 8:32:30 AM > Reading partitions...12/20/2021 8:32:31 AM > OK 12/20/2021 8:32:31 AM > Detecting writing method...12/20/2021 8:32:31 AM > OK 12/20/2021 8:32:31 AM > Reading security area...12/20/2021 8:32:32 AM > OK 12/20/2021 8:32:32 AM > Backup saved to "L22_357XXXXXXXXXX_20-12-2021_08-32-03.SEC" 12/20/2021 8:32:32 AM > Switching to Normal mode... 12/20/2021 8:33:22 AM > Found model LGL22 at port COM9 12/20/2021 8:33:24 AM > Writing security area...12/20/2021 8:33:26 AM > Failed! 12/20/2021 8:33:26 AM > Performed by 3.1.6 Software version. 12/20/2021 8:33:26 AM > Elapsed Time: 12:02:33 AM 12/20/2021 8:33:55 AM > -------------------------------------------------------------------------------- |
12-28-2021, 16:43 | #3 (permalink) |
Member: 2682769 Status: Offline Thanks Meter: 1 | Same result after Reset Security then applying unlock. . Still getting Security Failed. . The problem is with the software all the versions above 3.0.1 to 3.1.6. . Are giving an error when trying to unlock. . As I have stated I have been unlocking these for a while now. . Kindly double check if possible you can create a test software with the version before 3.0.1 I will appreciate since I can't roll back to old softwares Thanks |
01-04-2022, 13:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We already prepare a test version of software for you 3.1.6.02. Please, install this version from our Support area (support/SOFTWARE/Octoplus LG/TEST SOFTWARE/) then perform Unlock operation and post here result. |
01-05-2022, 10:13 | #5 (permalink) |
Member: 2682769 Status: Offline Thanks Meter: 1 | New Error. . . First Attempt. . . Welcome to Octoplus/Octopus Box LG Software version 3.1.6.02 Card S/N : 00010XXXXX -------------------------------------------------------------------------------- Work ID: 000000000211E2C3 Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: L22 Reading info... Model ID: LGL22 IMEI: 357873-05-XXXXX-X Android version: 4.4.2 Battery level: 26% Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGL22 at port COM9 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "L22_3578730506XXXXXX_05-01-2022_10-59- 56.SEC" Writing security area...OK Switching to Normal mode... Found model LGL22 at port COM9 Error code: Z1AL3CAS2Q Performed by 3.1.6.02 Software version. Second Attempt: 1/5/2022 11:02:16 AM > Transport: Connected 1/5/2022 11:02:18 AM > Authorized. 1/5/2022 11:02:20 AM > Work ID: 000000000211E3B2 1/5/2022 11:02:20 AM > Checking data...1/5/2022 11:02:21 AM > OK 1/5/2022 11:02:21 AM > Platform: LG Qualcomm 1/5/2022 11:02:21 AM > Selected port: COM9 1/5/2022 11:02:21 AM > Selected model: L22 1/5/2022 11:02:21 AM > Reading info... 1/5/2022 11:02:23 AM > Model ID: LGL22 1/5/2022 11:02:23 AM > IMEI: 000000-00-000000-0 1/5/2022 11:02:23 AM > Android version: 4.4.2 1/5/2022 11:02:23 AM > Battery level: 28% 1/5/2022 11:02:57 AM > Trying to enable Diagnostics ports...1/5/2022 11:02:57 AM > Failed! 1/5/2022 11:02:57 AM > Trying to enable Diagnostics ports... 1/5/2022 11:02:57 AM > Initializing ADB...1/5/2022 11:02:59 AM > OK 1/5/2022 11:02:59 AM > Waiting for phone...1/5/2022 11:03:00 AM > OK 1/5/2022 11:03:04 AM > Diagnostics ports are enbled! 1/5/2022 11:03:04 AM > Switching to Serial Port... 1/5/2022 11:03:20 AM > Found model LGL22 at port COM9 1/5/2022 11:03:20 AM > Unlocking... 1/5/2022 11:03:21 AM > Skip Read/Write QCN 1/5/2022 11:03:21 AM > Switching to Download mode...1/5/2022 11:03:47 AM > OK 1/5/2022 11:03:47 AM > Initializing flash...1/5/2022 11:03:49 AM > OK 1/5/2022 11:03:49 AM > Reading partitions...1/5/2022 11:03:49 AM > OK 1/5/2022 11:03:49 AM > Detecting writing method...1/5/2022 11:03:50 AM > OK 1/5/2022 11:03:50 AM > Reading security area...1/5/2022 11:03:50 AM > OK 1/5/2022 11:03:50 AM > Backup saved to "L22_000000000000000_05-01-2022_11-03-21.SEC" 1/5/2022 11:03:50 AM > Writing security area...1/5/2022 11:04:02 AM > OK 1/5/2022 11:04:02 AM > Switching to Normal mode... 1/5/2022 11:04:54 AM > Found model LGL22 at port COM9 1/5/2022 11:04:56 AM > Error code: Z1AL3CAS2Q 1/5/2022 11:04:56 AM > Performed by 3.1.6.02 Software version. 1/5/2022 11:04:56 AM > Elapsed Time: 12:02:41 AM |
01-06-2022, 00:31 | #7 (permalink) |
Member: 2682769 Status: Offline Thanks Meter: 1 | The state of all 12 phones is perfect. They are only network locked. I sent two logs operations because after getting that error from the test software the imei got to 0 but that's not is not a problem as I already know how to restore it. |
01-06-2022, 09:17 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please insert SIM card and record a video with phone's screen, where we can see, that device is locked and his SN/IMEI, then send us link with video we will check. |
