02-01-2022, 12:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Age: 31
Member: 1521524 Status: Offline Sonork: 100.1650887 Thanks Meter: 43 | LG LM-G820n imei repair fail [Solved] Work ID: 0000000002302AFD Checking data...OK Platform: LG Qualcomm Selected port: COM60 Selected model: G820N Reading info... Model ID: LM-G820N IMEI: 359964-10-112447-1 Android version: 11 Battery level: 53% Mode: Normal Firmware compiled date: Oct 13 2021 Firmware compiled time: 05:00:00 Firmware released date: Nov 19 2021 Firmware released time: 18:29:30 SW Version: MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK- 1.442561.2.444223.2 IMEI: 359964-xx-xxxxxx-x SPC: 000000 Fixing IMEI... New IMEI: 3576xx-xx-xxxxx-x Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-G820N Phone firmware version: LMG820NAT-00-V30d-LAO-COM-NOV- 19-2021+0 Kernel version: 4.14.190-perf+ (jenkins@MCSBS8R9) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Fri Nov 19 18:57:45 KST 202 Android version: 11 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: LGU Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bilalkhan1140 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...OK Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Platform: msmnile SW version: LMG820NAT-00-V30d-LGU-KR-NOV-19-2021+0 Android version: 11 LAF Version: 1.1 Product ID: HD60S190319002606 IMEI: 359964-10-112447-1 Target operator: LAO Hardware: rev_10 Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Writing security area... Please, put the phone in EDL Mode (Qualcomm 9008): 1. Press and hold "Vol-" and "Power" buttons. 2. As soon as the screen turns off, keep holding the "Vol-" and "Power" buttons and simultaneously press "Vol+" few times quickly. 3. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". Performed by 3.1.6 Software version. |
02-01-2022, 12:55 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We added you one more attempt. Please, download and install latest test Software v. 3.1.6.05 from Support Area (Path:/SOFTWARE/Octoplus LG/TEST SOFTWARE/install_octoplus_octopus_LG_3.1.6.05.exe) Then repeat operation once again and post here results. We will check it. Note: Read attentively Software instructions. Quote:
02-01-2022, 13:12 | #3 (permalink) |
Member: 1521524 Status: Offline Sonork: 100.1650887 Thanks Meter: 43 | THNX done Work ID: 00000000023035DC Checking data...OK Platform: LG Qualcomm Selected port: COM60 Selected model: G820N Reading info... Model ID: LM-G820N IMEI: 359964-10-112447-1 Android version: 11 Battery level: 47% Mode: Normal Firmware compiled date: Oct 13 2021 Firmware compiled time: 05:00:00 Firmware released date: Nov 19 2021 Firmware released time: 18:29:30 SW Version: MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK- 1.442561.2.444223.2 IMEI: 359xxxx-10-xxxxx-1 SPC: 000000 Fixing IMEI... New IMEI: 35xxxx-xxxx-xxxxx-0 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-G820N Phone firmware version: LMG820NAT-00-V30d-LAO-COM- NOV-19-2021+0 Kernel version: 4.14.190-perf+ (jenkins@MCSBS8R9) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27- bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Fri Nov 19 18:57:45 KST 202 Android version: 11 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: LGU Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: bilalkhan1140 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...OK Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Platform: msmnile SW version: LMG820NAT-00-V30d-LGU-KR-NOV-19-2021+0 Android version: 11 LAF Version: 1.1 Product ID: HD60S190319002606 IMEI: 35xxxxx-xx-xxxxxxx-1 Target operator: LAO Hardware: rev_10 Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Writing security area... Please, put the phone in EDL Mode (Qualcomm 9008): 1. Press and hold "Vol-" and "Power" buttons. 2. As soon as the screen turns off, keep holding the "Vol-" and "Power" buttons and simultaneously press "Vol+" few times quickly. 3. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". Found port COM9 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Resetting secutiy area...OK Backup saved to "G820N_3599xxxxxxxx_01-02-2022_17- 04-06.SEC" Rebooting phone...OK Switching to Normal mode... Found model LMG820NA* ÿ at port COM60 IMEI successfully fixed! Rebooting phone... Performed by 3.1.6 Software version. |
The Following User Says Thank You to m.bilal139 For This Useful Post: |
