05-13-2023, 16:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | LG LM-G850EMW Imei repair error [Answered] Checking data...OK Platform: LG Qualcomm Selected port: COM16 Selected model: G850EMW Reading info... Model ID: LM-G850EMW IMEI: 358624-10-234295-8 Android version: 12 Battery level: 63% Mode: Normal Firmware compiled date: Oct 10 2022 Firmware compiled time: 10:00:00 Firmware released date: Jan 10 2023 Firmware released time: 18:58:58 SW Version: MPSS.HE.1.0.c4-00133-SM8150_GEN_PACK- 1.516193.5.535850.3 IMEI: 35xxxxxxxxxx IMEI B: 35xxxxxxxxxx SPC: 000000 Fixing IMEI... New IMEI A: 355222-23-333222-1 New IMEI B: 355522-33-332222-4 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.2.3 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001F4D81F Checking data...OK Platform: LG Qualcomm Selected port: COM16 Selected model: G850EMW Reading info... Model ID: LM-G850EMW IMEI: 358624-10-234295-8 Android version: 12 Battery level: 64% Mode: Normal Firmware compiled date: Oct 10 2022 Firmware compiled time: 10:00:00 Firmware released date: Jan 10 2023 Firmware released time: 18:58:58 SW Version: MPSS.HE.1.0.c4-00133-SM8150_GEN_PACK- 1.516193.5.535850.3 IMEI: 35xxxxxxxx IMEI B: 35xxxxxxxxxx SPC: 000000 Fixing IMEI... New IMEI A: 355222-23-333222-1 New IMEI B: 355522-33-332222-4 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-G850EMW Phone firmware version: LMG850AT-00-V40b-LAO-COM-JAN-10-2023+0 Kernel version: 4.14.190-perf+ (jenkins@si-ch2-bld7) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Tue Jan 10 22:24:19 IST 202 Android version: 12 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: OPEN Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Performed by 3.2.3 Software version. |
