03-24-2021, 10:04 | #1 (permalink) |
Insane Poster Join Date: Mar 2014 Location: phagwara Age: 31
Member: 2145940 Status: Offline Sonork: 1001653706 Thanks Meter: 12 | LG LM-X210apm unlock error imei null [Solved] Work ID: 0000000000C7BE37 Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-174954-2 Android version: 8.1.0 Battery level: 77% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-174954-2 Bluetooth address: AC:F6:F7:2E:FC:AD Wi-Fi MAC address: 64:C2E:99:75:67 SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: lgoctopus258 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_355437101749542_24-03-2021_ 14-14-49.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210APM_355437101749542_24-03-2021_ 14-20-49.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210AP* ÿh at port COM19 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: lgoctopus258 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.1.0 Software version. |
03-24-2021, 10:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. To restore IMEI, please write backup: "LMX210APM_355437101749542_24-03-2021_14-20-49.SEC" then do Unlock operation via SD card method and post here result. No need credits for repeat operation! |
03-24-2021, 11:22 | #3 (permalink) |
Member: 2145940 Status: Offline Sonork: 1001653706 Thanks Meter: 12 | Thanks its DONE Work ID: 0000000000C7CFF9 Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 77% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-00-V20e-ATT-US-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS02S190516005207 IMEI: 000000-00-000000-0 Target operator: ATT Hardware: rev_10 Opening "LMX210APM_355437101749542_24-03-2021_14-20- 49.SEC"... Writing security area... Copying on SD Card... Writing SP1... Writing SP2... Writing SP3... Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Writing SP1... Connecting to phone...OK Initializing flash...OK Writing SP2... Connecting to phone...OK Initializing flash...OK Writing SP3... Connecting to phone...OK Initializing flash...OK Rebooting phone... Performed by 3.1.0 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000C7D186 Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-174954-2 Android version: 8.1.0 Battery level: 78% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-174954-2 Bluetooth address: AC:F6:F7:2E:FC:AD Wi-Fi MAC address: 64:C2E:99:75:67 SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: lgoctopus258 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 0 credits. To perform "Unlock" operation you need to have 0 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VS02S190516005207 IMEI: 355437-10-174954-2 Target operator: ATT Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.1.0 Software version. |
The Following 2 Users Say Thank You to msinghbal83 For This Useful Post: |
