02-01-2021, 15:44 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Türkiye Age: 44
Member: 341207 Status: Offline Thanks Meter: 14 | Lg nexsus 5 d820 imei repair ok but imei 0 [Solved] phone versıon 6.0.1 Welcome to Octoplus/Octopus Box LG Software version 3.0.5 Card S/N : 000201A377 -------------------------------------------------------------------------------- Work ID: 8637824 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8637851 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Phone firmware version: Kernel version: 3.4.0-gcf10b7e (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Sep 19 22:14:08 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Aug 12 2016 Firmware released time: 10:07:47 SW Version: M8974A-2.0.50.2.30 SPC: 000000 Fixing IMEI... New IMEI: 355136-05-0000000 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button.Failed! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8638067 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8638139 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Phone firmware version: Kernel version: 3.4.0-gcf10b7e (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Sep 19 22:14:08 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Aug 12 2016 Firmware released time: 10:07:47 SW Version: M8974A-2.0.50.2.30 SPC: 000000 Fixing IMEI... New IMEI: 355136-05-00000000 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D820_Bad_01-02-2021_17-21-16.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 3.0.5 Software version. |
02-01-2021, 16:02 | #2 (permalink) | |
Member: 341207 Status: Offline Thanks Meter: 14 | Quote:
andorıd 4.4.2 downgarde but fail Welcome to Octoplus/Octopus Box LG Software version 3.0.5 Card S/N : 000201A377 -------------------------------------------------------------------------------- Work ID: 8637824 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8637851 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Phone firmware version: Kernel version: 3.4.0-gcf10b7e (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Sep 19 22:14:08 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Aug 12 2016 Firmware released time: 10:07:47 SW Version: M8974A-2.0.50.2.30 SPC: 000000 Fixing IMEI... New IMEI: 355136-05-545956-7 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button.Failed! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8638067 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info...Failed! Could not detect mode! Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8638139 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Phone firmware version: Kernel version: 3.4.0-gcf10b7e (android- [email protected]) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Sep 19 22:14:08 UTC 201 Android version: 6.0.1 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Trying to enable Diagnostics ports... Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 07:00:00 Firmware released date: Aug 12 2016 Firmware released time: 10:07:47 SW Version: M8974A-2.0.50.2.30 SPC: 000000 Fixing IMEI... New IMEI: 355136-05-545956-7 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D820_Bad_01-02-2021_17-21-16.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*˙h°Â at port COM19 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 3.0.5 Software version. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Work ID: 8641820 Checking data...OK Platform: LG Qualcomm Selected port: COM26 Selected model: D820 Reading info... IMEI: 358239-05-488346-9 Android version: Battery level: 23% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD820AT-00-V10b-NXS-XX-OCT-31-2013-KRT16M- USER-32G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: SM06S131127004891 IMEI: 358239-05-488346-9 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD820AT-00-V10a-NXS-OCT-01-2013-KFS78N- USER-16G+0.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8641954 Checking data...OK Platform: LG Qualcomm Selected port: COM26 Selected model: D820 Reading info... IMEI: 358239-05-488346-9 Android version: Battery level: 23% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD820AT-00-V10b-NXS-XX-OCT-31-2013-KRT16M- USER-32G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: SM06S131127004891 IMEI: 358239-05-488346-9 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD820AT-00-V10a-NXS-OCT-01-2013-KFS78N- USER-16G+0.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 3.0.5 Software version. -------------------------------------------------------------------------------- Work ID: 8642094 Checking data...OK Platform: LG Qualcomm Selected port: COM26 Selected model: D820 Reading info... IMEI: 358239-05-488346-9 Android version: Battery level: 22% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD820AT-00-V10b-NXS-XX-OCT-31-2013-KRT16M- USER-32G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: SM06S131127004891 IMEI: 358239-05-488346-9 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD820AT-00-V10a-NXS-OCT-01-2013-KFS78N- USER-16G+0.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 3.0.5 Software version. | |
02-01-2021, 16:08 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please download and install latest software version 3.0.9 and try to repeat Repair IMEI operation again. Post here results. |
