02-07-2022, 20:37 | #1 (permalink) |
Insane Poster Join Date: Feb 2019
Member: 2895768 Status: Offline Thanks Meter: 10 | X540HM Repair IMEI issue [Answered] Login:MowjbvZFoh Welcome to Octoplus/Octopus Box LG Software version 3.1.6 Card S/N : 000103795B -------------------------------------------------------------------------------- Connecting to server 0...OK Username: X6caeTXNgr Authorizing...OK Checking balance...OK Your balance: 0 credits. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: wuwFBW11Wa Authorizing...Failed! Login error: Wrong password! -------------------------------------------------------------------------------- Connecting to server 0...OK Username: wuwFBW11Wa Authorizing...Failed! Login error: Wrong password! -------------------------------------------------------------------------------- Connecting to server 0...OK Username: MowjbvZFoh Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000023736AC Checking data...OK Platform: LG MTK Selected port: COM6 Selected baudrate: 921600 Selected model: X540HM Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM40 Mode: Emergency Initializing flash...OK Model ID: LM-X540HM Platform: mt6765 Code name: mmh45lm Android version: 10 SW version: LMX540HMAT-00-V20a-334-020-OCT-28-2021+6 LAF Version: 1.1 Product ID: CB42S191121005859 IMEI: 358946-10-070151-7 Target operator: LAO Hardware: rev_10 Battery level: 61% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 358946-10-070151-7 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: MowjbvZFoh Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM40 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM5 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC flash chip: .90014A68.42386150.3E0362A1.3C79B6B9 eMMC flash chip: Unknown: hB8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "X540HM_358946100701517_07-02-2022_13- 21-59.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.6 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: MowjbvZFoh Authorizing...OK Checking balance...OK Your balance: 0 credits. |
02-14-2022, 16:20 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. We added you one more attempt. Please, download and install latest software version 3.1.7 then repeat Repair Imei operation again follow software manual and post here log. |
