01-17-2022, 15:45
#1 (permalink)
Member: 2182242
Sonork: No Thanks Meter: 59 | LGH961N Dead Flash Done After Frp Romove With Octoplus Quote:
Work ID: 00000000021FA6DF
Checking data...OK
Platform: LG Qualcomm
Selected port: COM51
Selected model: H961N
Reading info...
Model ID: LG-H961N
IMEI: 000000-00-000000-0
Android version: 5.1.1
Battery level: 58%
Mode: Emergency
Initializing flash...OK
Platform: msm8992
SW version: LGH961NAT-00-V10d-GLOBAL-COM-JUL-14-2016+0
LAF Version: 1.2
Product ID: E0000011704201438
IMEI: 357905-06-276090-4
Target operator: GLOBAL
Hardware: rev_10
Opening "H961N30a_00_0519.kdz"...OK
Firmware version: LGH961NAT-00-V30a-GLOBAL-COM-MAY-19-
2017+0
Firmware model: LG-H961N
Firmware type: 0100
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without
any installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to
your computer during the flashing!
Prepairing firmware...OK
Selecting firmware partitions...OK
Selected default partitions!
Sending signature...Failed!
Setting options...OK
Do you want to format User Data?
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing 1/73 PrimaryGPT_0.bin...OK
Writing 2/73 modem_16384.bin...OK
Writing 3/73 pmic_196608.bin...OK
Writing 4/73 sbl1_197632.bin...OK
Writing 5/73 tz_199680.bin...OK
Writing 6/73 sdi_201728.bin...OK
Writing 7/73 hyp_202752.bin...OK
Writing 8/73 rpm_203776.bin...OK
Writing 9/73 aboot_204800.bin...OK
Writing 10/73 sbl1bak_208896.bin...OK
Writing 11/73 pmicbak_210944.bin...OK
Writing 12/73 hypbak_211968.bin...OK
Writing 13/73 tzbak_212992.bin...OK
Writing 14/73 rpmbak_215040.bin...OK
Writing 15/73 abootbak_216064.bin...OK
Writing 16/73 sdibak_220160.bin...OK
Writing 17/73 persist_278528.bin...OK
Writing 18/73 sec_360448.bin...OK
Writing 19/73 rct_363520.bin...Skipped!
Writing 20/73 laf_376832.bin...OK
Writing 21/73 boot_475136.bin...OK
Writing 22/73 recovery_557056.bin...OK
Writing 23/73 raw_resources_737280.bin...OK
Writing 24/73 raw_resourcesbak_745472.bin...OK
Writing 25/73 factory_753664.bin...OK
Writing 26/73 system_901120.bin...OK
Writing 27/73 system_1163264.bin...OK
Writing 28/73 system_1165448.bin...OK
Writing 29/73 system_1429456.bin...OK
Writing 30/73 system_1689736.bin...OK
Writing 31/73 system_1693784.bin...OK
Writing 32/73 system_1953744.bin...OK
Writing 33/73 system_2211840.bin...OK
Writing 34/73 system_2214024.bin...OK
Writing 35/73 system_2218072.bin...OK
Writing 36/73 system_2478032.bin...OK
Writing 37/73 system_2736128.bin...OK
Writing 38/73 system_2738312.bin...OK
Writing 39/73 system_2742360.bin...OK
Writing 40/73 system_3002320.bin...OK
Writing 41/73 system_3262600.bin...OK
Writing 42/73 system_3266648.bin...OK
Writing 43/73 system_3526608.bin...OK
Writing 44/73 system_3788752.bin...OK
Writing 45/73 system_4050896.bin...OK
Writing 46/73 system_4313040.bin...OK
Writing 47/73 system_4571136.bin...OK
Writing 48/73 system_4575184.bin...OK
Writing 49/73 system_4837328.bin...OK
Writing 50/73 system_5099472.bin...OK
Writing 51/73 system_5361616.bin...OK
Writing 52/73 system_5623760.bin...OK
Writing 53/73 system_5885904.bin...OK
Writing 54/73 system_6148048.bin...OK
Writing 55/73 system_6410192.bin...OK
Writing 56/73 system_6672336.bin...OK
Writing 57/73 system_6934480.bin...OK
Writing 58/73 system_7196624.bin...OK
Writing 59/73 system_7456904.bin...OK
Writing 60/73 system_7460952.bin...OK
Writing 61/73 system_7720912.bin...OK
Writing 62/73 system_7981192.bin...OK
Writing 63/73 system_7985240.bin...OK
Writing 64/73 system_8245200.bin...OK
Writing 65/73 system_8507344.bin...OK
Writing 66/73 system_8769488.bin...OK
Writing 67/73 system_9031632.bin...OK
Writing 68/73 system_9289728.bin...OK
Writing 69/73 system_9551872.bin...OK
Writing 70/73 system_9554936.bin...OK
Writing 71/73 cust_9674752.bin...OK
Writing 72/73 cust_9936896.bin...OK
Writing 73/73 BackupGPT_122141696.bin...Skipped!
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Performed by 3.1.6 Software version.
Work ID: 00000000021FAE9F
Checking data...OK
Selected port: COM52
Please, put the phone into download mode manually (Power
phone OFF (reconnect battery), press and hold "Vol+" button and
connect the cable (or P999 cable)).
Reading info...
Model ID: LG-H960ATR
Android version: 7.0
Battery level: 47%
Mode: Emergency
Platform: msm8992
SW version: LGH960ATRAT-00-V30a-GLOBAL-COM-MAY-19-2017
+0
LAF Version: 1.1
Hardware: rev_10
Reset FRP operation for H961N will delete all user data on the
phone (contacts, pictures and others)!
Do You want to continue?
Detecting writing method...OK
Resetting FRP Lock...
Writing loader...
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
Step 7...
Step 8...
Step 9...
Step 10...OK
Writing userdata...OK
Formating encrypt...OK
Restoring loader...OK
Resetting FRP lock successfully completed!
Rebooting phone...
To complete the operation, please make Factory Reset (Go to
"Settings" -> "General" -> "Backup & reset" -> "Factory data reset",
press "Reset phone" and "Erase everything" buttons).
| Thanks Octoplus Team
Br,Mani Gsm |
