02-13-2022, 12:34 | #3 (permalink) |
Junior Member Join Date: Feb 2022 Location: Iran
Member: 3006958 Status: Offline Thanks Meter: 0 | LG drivers already installed. I believe to detect as Qualcomm HS-USB Diagnostic 9008 port we need Qualcomm drivers that is installed too as It can detect in EDL mode Qualcomm HS-USB QDLoader. |
02-14-2022, 13:12 | #5 (permalink) | |
Member: 3006958 Status: Offline Thanks Meter: 0 | Quote:
The phone is booting normally and baseband is working. Also recently downgraded from android 11 (V500N30c) to android 10 (V500N20b) as Octopus can only change IMEI on android 9 and 10 on this model. Last edited by Octopus box; 02-14-2022 at 13:37. | |
02-14-2022, 13:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. Please, install the Necessary drivers. Software version 3.1.7, select V500N then install drivers from Cable & Manual. |
02-27-2022, 21:15 | #7 (permalink) | |
Next repair IMEI failed using Octopus. What's wrong? | |
02-27-2022, 22:16 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Quote:
Please read our previous post attentively. Especially our recommendation to use the latest Software version. Also, after the operation is completed, post here full Software log. We'll check it. | |
03-01-2022, 12:52 | #9 (permalink) | |
you can check logs on screenshot attached. | |
